> Building a Rotisserie
McMark
post Dec 21 2011, 08:58 PM
914 Freak!
Tomorrow I start cutting metal and building the rotisserie I should have had a long time ago. I'm actually quite eager to get going on this project, more than I anticipated. Not only because I've wanted a rotisserie for a long time, but also because once it's finished the 914 that's sitting on the Celette bench will go on the rotisserie. Then I can put a 66 912 project up on the bench and start building my first set of Celette fixtures. Even though they'll be for a 912, the techniques I learn will make the 914 fixtures even better.
I'll be posting pictures of my progress tomorrow, but I couldn't wait to share. (IMG:style_emoticons/default/boldblue.gif)
leebenedi
post Dec 23 2011, 03:25 AM
Region Association: Spain
Just one question. I plan on putting my 914 on a rotisserie but the front bumper holes are quite rusted. Is that a problem?
Thank you,
Lee
9fourteen
post Dec 23 2011, 07:53 AM
QUOTE(leebenedi @ Dec 23 2011, 04:25 AM) *
Lee,
I have the same issue and assumed "yes" since that is where I plan on mounting the rotisserie. I am a complete novice on this stuff so I figured this was a good place to start perfecting my welding and metal working skills since it would not be visible and not as critical structurally.
Here is what I found when I pulled the bumper
Here is what I have cut out, still need to grind it a bit
Here is my patch. (second attempt) It's starting to look ok. Just need to get it cleaned up and welded in.
Here is a crude drawing of what I was thinking as a solution to getting the car up high enough to spin. (this drawing is missing a lot of stuff. it's just to show my raising and lowering idea)
McMark   Building a Rotisserie   Dec 21 2011, 08:58 PM
kg6dxn   COOL! :Qarl:   Dec 21 2011, 09:00 PM
strawman   There is no way I could have stripped, repaired an...   Dec 21 2011, 11:46 PM
Elliot Cannon   Tomorrow I start cutting metal and building the r...   Dec 22 2011, 12:20 AM
McMark   The actual Celette bench is just a big-ass cart. ...   Dec 22 2011, 12:28 AM
Elliot Cannon   So it basically acts as kind of a factory jig?   Dec 22 2011, 12:31 AM
Elliot Cannon   Here he is ladies and gentlemen. The man his own...   Dec 22 2011, 12:33 AM
McMark   That's totally right. It's mentioned by ...   Dec 22 2011, 12:51 AM
RobW   :trophy: :trophy: :trophy: :trophy: :trophy: ...   Dec 22 2011, 07:42 AM
FourBlades   Just make sure you buy enough 2x4s before you star...   Dec 22 2011, 02:11 PM
KELTY360   Just make sure you buy enough 2x4s before you sta...   Dec 22 2011, 06:22 PM
URY914   My advice is to use at least 5" steel caster ...   Dec 22 2011, 04:07 PM
URY914   My advice is to use at least 5" steel caster...   Dec 23 2011, 08:28 PM
aircooledtechguy   [quote name='URY914' post='1593389' date='Dec 22 ...   Dec 24 2011, 09:54 AM
cary   My advice is to use at least 5" steel caster...   Dec 10 2012, 10:40 PM
9fourteen   This may be a dumb question but how do you get the...   Dec 22 2011, 06:29 PM
jcd914   This may be a dumb question but how do you get th...   Dec 22 2011, 06:58 PM
okieflyr   This may be a dumb question but how do you get t...   Dec 22 2011, 07:46 PM
bigkensteele   This may be a dumb question but how do you get th...   Dec 22 2011, 07:07 PM
KELTY360   This may be a dumb question but how do you get t...   Dec 22 2011, 07:28 PM
FourBlades   To get it on the rotisserie, just borrow a set of ...   Dec 22 2011, 07:26 PM
McMark   :agree: Lifting it manually is a great option. Al...   Dec 22 2011, 11:55 PM
leebenedi   Just one question. I plan on putting my 914 on a r...   Dec 23 2011, 03:25 AM
9fourteen   Just one question. I plan on putting my 914 on a ...   Dec 23 2011, 07:53 AM
leebenedi   Thank you for the responses. My rust is not as bad...   Dec 24 2011, 01:55 AM
mepstein   Thank you for the responses. My rust is not as ba...   Dec 24 2011, 10:39 AM
scotty b   I know the bumper holes are the standard mounting ...   Dec 23 2011, 08:00 AM
scotty b   Put the jack on the inside. Placing it on the outs...   Dec 23 2011, 08:02 AM
scotty b   this   Dec 23 2011, 08:07 AM
McMark   :agree: Lee, you should fix the bumper mounts FIRS...   Dec 23 2011, 11:04 AM
scotty b   :agree: Lee, you should fix the bumper mounts FIR...   Dec 23 2011, 05:22 PM
strawman   To get the body on the rotisserie, you should stri...   Dec 23 2011, 11:35 AM
McMark   Goeff, adding a ring to the top of your body cross...   Dec 23 2011, 02:44 PM
McMark   Got the wheels and the center legs completed. Now...   Dec 23 2011, 04:14 PM
strawman   http://www.914world.com/bbs2/uploads/post-419-1324...   Dec 24 2011, 01:25 AM
Elliot Cannon   Are those casters big enough?   Dec 23 2011, 07:54 PM
9fourteen   I am curious as to why you put the casters on the ...   Dec 23 2011, 08:35 PM
McMark   Casters were from another project. If they die, I...   Dec 23 2011, 10:12 PM
RobW   Casters were from another project. What... Li...   Dec 24 2011, 01:09 AM
shuie   I welded angle iron on the end of the square tube ...   Dec 24 2011, 11:58 AM
jimkelly   looks good. the caster brackets look like ankle b...   Dec 24 2011, 06:39 AM
McMark   Finally found the bearing setup I wanted to make t...   Jan 25 2012, 05:36 PM
ConeDodger   Finally found the bearing setup I wanted to make ...   Mar 10 2012, 09:20 PM
scotty b   :thumbsup: I thought aboot using rear bearing...   Jan 25 2012, 05:41 PM
burton73   Mark, This is on my unit I bought it for $11...   Jan 25 2012, 06:04 PM
McMark   I'm building a similar locking pin setup. The...   Jan 25 2012, 06:19 PM
mr914   I built my rotiserie a number of years ago. I use...   Mar 10 2012, 06:49 PM
mr914   Built it so I could break it down and store it. S...   Mar 10 2012, 07:05 PM
sixnotfour   No... But the steering wheel Is.. :lol: :rotfl:   Mar 10 2012, 09:50 PM
McMark   Finally finished up the brackets for the rotisseri...   Jun 25 2012, 08:29 PM
FourBlades   Looks great! That is very innovative. Now ju...   Jun 25 2012, 08:45 PM
jsconst   I happen to be there when they were rolling it out...   Jun 25 2012, 08:54 PM
scotty b   Hey Mark I've got to build another for a 911 I...   Jun 26 2012, 06:13 PM
McMark   It's balanced enough to handle by myself. I h...   Jun 26 2012, 10:53 PM
McMark   Time to build 914 fixtures since my restoration pr...   Dec 10 2012, 08:01 PM
Socalandy   Did I miss it or did everyone pass on saying... I...   Dec 10 2012, 08:09 PM
McMark   Just finished up the rear bar. Tomorrow it goes u...   Dec 10 2012, 09:42 PM
SirAndy   Can't wait to put this to "good" use...   Dec 10 2012, 10:14 PM
bigkensteele   Can't wait to put this to "good" us...   Dec 12 2012, 08:15 PM
914Eric   Nice! :popcorn:   Dec 10 2012, 10:21 PM
McMark   I'm going to try out the methods described in ...   Dec 11 2012, 10:26 AM
Gint   Love the steering wheel!   Dec 11 2012, 11:50 AM
McMark   914 fixtures complete! :boing: Spent a lot...   Dec 12 2012, 08:10 PM
McMark   Yes. :evilgrin:   Dec 12 2012, 08:17 PM
KELTY360   Paint it yellow...the work will go faster!   Dec 13 2012, 12:47 AM
jaxdream   What type of chassis leaning against the wall in t...   Dec 13 2012, 10:50 AM
McMark   Type3 VW chassis. We welded new pans on it.   Dec 13 2012, 10:54 AM
jaxdream   Ahh , thought so , but wasn't 100% sure . VW w...   Dec 13 2012, 11:05 AM
FourBlades   914 Limo on the rotisserie!!! :popcor...   Dec 13 2012, 11:14 AM
- Lo-Fi Version Time is now: 22nd November 2026 - 08:01 AM
