Paint questions? Painted both trunks, Repainted front trunk, Interior floor & rear trunk lid |
JRust |
Dec 22 2011, 02:55 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay so I am repainting my trunks in my LE. I had some paint put into cans when I bought the paint originally. Just so I would have it for touchup & whatever. I have gone through all 3 cans & am not finished. Painting with the rattle can has been a bit of a challenge. Now I need to get some more paint.
So should I just get a couple more in rattle cans? Or should I buy a paint gun at Harbor Freight? If I buy a gun do you have one you would recommend for a novice? Also if I go that route do I have to do anything different with the paint? When I get it in the can do I have to mix anything? |
vwsamba |
Dec 22 2011, 08:16 PM
Newbie Group: Members Posts: 46 Joined: 20-November 10 From: Malibu, CA Member No.: 12,407 Region Association: None |
You could get the correct color paint with hardner and then spray it through a preval sprayer. Its like a reusable spray can with a seperate paint pot. I think they have them at home depot. For larger areas a real spray gun is best so the idea above about taking the paint and lid to a shop is also a good idea.
JRust |
Dec 22 2011, 11:10 PM
You could get the correct color paint with hardner and then spray it through a preval sprayer. Its like a reusable spray can with a seperate paint pot. I think they have them at home depot. For larger areas a real spray gun is best so the idea above about taking the paint and lid to a shop is also a good idea. Sorry if some of my questions are a little dumb. Obviously I have not painted & am not familiar with the process (IMG:style_emoticons/default/confused24.gif) So if I get my paint by the pint or gallon. I have to mix in hardner when I go to spray it?Does the rattle can already have the hardner in it? |
Lennies914 |
Dec 23 2011, 08:31 AM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
You could get the correct color paint with hardner and then spray it through a preval sprayer. Its like a reusable spray can with a seperate paint pot. I think they have them at home depot. For larger areas a real spray gun is best so the idea above about taking the paint and lid to a shop is also a good idea. Sorry if some of my questions are a little dumb. Obviously I have not painted & am not familiar with the process (IMG:style_emoticons/default/confused24.gif) So if I get my paint by the pint or gallon. I have to mix in hardner when I go to spray it?Does the rattle can already have the hardner in it? Not all paints require a hardner. I think most base coat paints are just thinned with a reducer and sprayed. It is the clear coats that require the hardner and some single stage paints. If I recall the hardner is even optional in the single stage paints. As for paint guns, I've always used the HF guns for stricktly primer guns. I had a coulpe of high dollar guns, but the paint shop was rebuilding my gun for me one day when I needed it. I ended up spending $99 on a gun at lowes (Kobalt) and it turned out to be my favorite gun. I payed less for the new Kobalt than the paint shop charged me to cean and rebuild my devilviss gun. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:37 PM |
