what did you do to your 914 today |
mrbubblehead |
Dec 17 2011, 08:07 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
914werke |
Dec 28 2011, 10:58 AM
"I got blisters on me fingers" Group: Members Posts: 10,115 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Struggled getting the impeller hub off the front of the crank in a motor Im working on.
Broke a puller, heat, banging ... no go. Had to take a break so went over to Jons to deliver some holiday cheer to his children & help him pull his front suspension |
PeeGreen 914 |
Dec 28 2011, 12:12 PM
Struggled getting the impeller hub off the front of the crank in a motor Im working on. Broke a puller, heat, banging ... no go. Had to take a break so went over to Jons to deliver some holiday cheer to his children & help him pull his front suspension Holiday cheer it was (IMG:style_emoticons/default/beerchug.gif) . Campbell is still cooking with the play kitchen stuff (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 31st May 2024 - 06:07 PM |
