what did you do to your 914 today |
mrbubblehead |
Dec 17 2011, 08:07 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
TC 914-8 |
Dec 30 2011, 07:30 PM
Senior Member Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
Thought it would be a good idea to pull my oil pan (SBC) and fix some oil leaks with a new Felpro 1 peice pan gasket. Got it all together and oil poured out of the front pan seal worse than before. Turns out Felpro makes several types. Thick front seal / thin front seal. $35.00 later I bought the thick front seal, one peice gasket. got it all together, full of new oil and she's ready to run.
Took her for a run around the block, no leaks, all is good for now. Any SBC's or V8's out there I recommend the one piece gasket, they seal like a champ and very easy to install, so easy I did it twice (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 03:50 AM |
