what did you do to your 914 today |
mrbubblehead |
Dec 17 2011, 08:07 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
DRPHIL914 |
Dec 29 2011, 11:55 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Tomorrow, or rather this morning( its12:48- watching the Baylor football game- RGIII,)
I will be pulling the tank to che k for leaks, replacing fuel lines, and while the tank is out i'm replace img the fresh air motor, then putting in a new CHT. Then new brake pads in front. Yesterday the rims got polished . |
DRPHIL914 |
Dec 30 2011, 09:59 PM
Tomorrow, or rather this morning( its12:48- watching the Baylor football game- RGIII,) I will be pulling the tank to che k for leaks, replacing fuel lines, and while the tank is out i'm replace img the fresh air motor, then putting in a new CHT. Then new brake pads in front. Yesterday the rims got polished . Update: Pulled fuel tank, no leaks! Pulled out the fresh air box, put in new used fresh air box from Tomas- it works, tested contacts at the fan cleaned the contacts on the sliders don't but for some reason I can only get the fan to work on the middle setting speed #2. Better than nothing like before, but I am not satisfied. The contacts touch. All that i will reevaluate another day. All that took so long I never got to figure out my window washer issue, or replacing the c.h.t. ah, but there is tomorrow! (I i've had the whole week off but only spent a few hours on the car. ) |
Lo-Fi Version | Time is now: 8th June 2024 - 05:25 PM |
