> Video added: Clutch cable figured out...new problem, Clutch "lever" is "floppy"
billh1963
post Jan 1 2012, 11:45 AM
Car Hoarder!
Okay....I see why the seller sold the car (IMG:style_emoticons/default/dry.gif)
I've got the clutch cable figured out but when I went to attach the cable to the clutch lever at the transmission the lever arm just flops around. There is no tension on it to release the clutch disc. I assume this means I'll be pulling the engine or transmission?
EdwardBlume
post Jan 1 2012, 11:56 AM
You can have the transmission out in 1 hour or less. Don't forget the ground strap attaching the body above the transmission.
billh1963
post Jan 1 2012, 12:03 PM
Car Hoarder!
QUOTE(RobW @ Jan 1 2012, 12:56 PM) *
Will do. Haynes manual says the transmission has to be pulled with the engine. Obviously, that is not the case. Anyone have a procedure or a link?
The clutch disc is very good (I hate to admit it but I have used the starter to move the car in car up trailer ramps)! I hope to reuse it.
So, what should I be looking for once I pull it? Broken lever, release bearing issues?
- Lo-Fi Version Time is now: 26th August 2025 - 11:59 PM
