Which dizzy is the best option, The best bang for my buck |
tscrihfield |
Jan 3 2012, 08:50 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
Here is the deal... I finished up my engine early last month and I am still piecing together my FI system to what I want. However, I want to get my engine broke in and ready to install. I don't want to spend a ton on a distributor (that will be getting yanked soon after) but I also want a good setup to run until the FI setup is ready to go. Give me some options gurus!
Can I run this with a Bosch blue i have sitting around?... http://www.amazon.com/Pertronix-D186604-Fl...r/dp/B004C02I1S I'd rather not run vacuum if I don't have to... I just set up a test stand to fire this bad boy up... Oh and I'll be running a set of dual webbers with it .... |
mrbubblehead |
Jan 3 2012, 09:17 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
price all depends. the chinese ones are less than 100 bucks. i bet you could find a used german one on the samba for 50.00. what kind of distributor are you thinking about running for you FI? if your webers have vacumm ports you could run an svda distributor and the webers will work real well and get good gas mileage. wht buy twice tho. why not just run the dizzy you gonna use for your FI? or are you going with a crank fire config.
tscrihfield |
Jan 3 2012, 09:26 PM
price all depends. the chinese ones are less than 100 bucks. i bet you could find a used german one on the samba for 50.00. what kind of distributor are you thinking about running for you FI? if your webers have vacumm ports you could run an svda distributor and the webers will work real well and get good gas mileage. wht buy twice tho. why not just run the dizzy you gonna use for your FI? or are you going with a crank fire config. I actually designed my own trigger wheel driven dizzy with the combo of a crank wheel as well. This way I can run sequential FI. I actually am carb retarded when it comes to VW engines I converted my old bug to FI as well with a setup from CB. The webers do have vac ports. So vac advance is the way to go if I go 009 route? Thanks BTW! |
Lo-Fi Version | Time is now: 1st June 2024 - 06:07 PM |
