> Vellios-JWest shift linkage progress thread, Started fabbing Vellios/JWest shift linkage
914dave
post Jan 7 2012, 05:35 PM
914 Addict
Now that my six conversions has progressed the point where the rust is out of the chassis and the 3.2 mated to the 915 are mounted in the car. I'm taking this winter to fabricate shift linkage from the Vellios 915 to the JWest shifter. After finishing the rebuild of the 915, I realized that the shift pattern would be reversed in the car. 5th/reverse would be towards the drivers side of the car. I didn't like this idea. So I'm building a riser for the shifter to reverse the direction fo the pattern. I wanted the linkage to be very crisp. I'm using industrial U joints and spherical bearings where I can. This is the first part of the project, the firewall bushing. I'll be using the stock rubber accordian boot in this setup for weather protection. the following pix are fo the bearing and the nylon housing used to mount it to the firewall. the first pic is the original 914 tunnel shift rod machined down to fit in the spherical bearing. The final pic show shows it mounted with 2 screws, I'll drill for the other 2 when I get the motor out of the way.
914dave
post Jan 8 2012, 10:50 AM
914 Addict
"I bought Martin Bott's 916 kit from Germany. I thought the Vellios used a 914 side shift pivot arm on the trans. Yours looks more like a real 916 side shift console."
Steve,
You're right about the later Vellios kits, they had the sideshift style console. The early ones had the 916 style console. I used pic's of Bott's kit to fabricate the internal bracket for my kit that was missing. My kit was also missing a shift lever and was the end case was machined incorrectly. John ( here on World) lent me a lever out of his Vellios to reverse engineer. Thanks again John! Chris Foley helped me out with pic's of his Bott installation for mounting the internal supports bracket. I made a fixture with my 901 to check the mounting alignment of the Vellios and machined it accordingly. My kit was very cheap and I didn't know it was missing parts. I found it at a Porsche race shop swap meet, I didn't have time to check everything out before I bought it. I'm just lucky that people here helped me out and I have a machine shop at my disposal. Here are pic's of the internal shift rod support that I made and some of the shift console that John wanted.
here are pic's of the shift lever that John lent me to fab
Attached Image]"
John
post Jan 8 2012, 03:03 PM
member? what's a member?
Attached Image]"
Glad to help! The parts you made were by far nicer than the original Vellios part.
I'm glad that you are getting closer to putting it all together. One thought on your shifter question would be to find out how is the German guy (who is making parts to clone a 916 box) is shifting his.
I had assumed that a 915 shifter tower would be used. I know that is what is used with the "later" Vellios side shift 915 kits.
914dave   Vellios-JWest shift linkage progress thread   Jan 7 2012, 05:35 PM
Steve   What kind of shifter are you going to use? I have...   Jan 7 2012, 06:12 PM
wingnut86   :popcorn:   Jan 7 2012, 06:38 PM
Dr Evil   :popcorn:   Jan 7 2012, 06:44 PM
Steve   :popcorn: FYI popcorn is good for you!!   Jan 7 2012, 06:55 PM
bigkensteele   Just curious - is it not possible to fabricate a c...   Jan 7 2012, 07:27 PM
Bob L.   Just curious - is it not possible to fabricate a ...   Jan 7 2012, 07:53 PM
bigkensteele   Pertinent?? Fancy word, Are you getting impertin...   Jan 7 2012, 09:49 PM
914dave   I'm using the 914 rennshift, I've used it ...   Jan 7 2012, 07:52 PM
John   I'm using the 914 rennshift, I've used it...   Jan 7 2012, 08:55 PM
dudley4   I'm using the 914 rennshift, I've used it...   Jan 7 2012, 09:46 PM
GeorgeRud   I also have a Vellios 916 conversion, and use a st...   Jan 7 2012, 09:54 PM
914dave   "I am wondering what kind of muffler you will...   Jan 8 2012, 07:32 AM
Steve   I also have a 914 Rennshift today on my 914 trans....   Jan 8 2012, 09:19 AM
914dave   "I bought Martin Bott's 916 kit from Germ...   Jan 8 2012, 10:50 AM
John   Glad to help! The parts you made were by f...   Jan 8 2012, 03:03 PM
914dave   OK guys. I know it's been a while. Went to som...   Feb 12 2012, 07:29 PM
914dave   Here's a pic with the shifter mounted in the c...   Feb 12 2012, 07:52 PM
914dave   Here's some pix of the shifter assembly from t...   Feb 12 2012, 08:03 PM
Eric_Shea   Holy cool-shit Batman. Amazing work Dave.   Feb 12 2012, 08:08 PM
GeorgeRud   Thanks for the pics, I didn't know Vellios had...   Feb 12 2012, 08:49 PM
wingnut86   Did you keep detailed measurements, material lists...   Feb 12 2012, 09:26 PM
914dave   Thanks guys. I've got drawings if anyone woul...   Feb 13 2012, 08:12 AM
914dave   With the shifter base being above the carpet I had...   Feb 16 2012, 08:04 PM
Dion   Awesome work Dave, Awesome! Cheers,Dion :beer...   Feb 16 2012, 08:43 PM
wingnut86   SEXY :drooley:   Feb 16 2012, 09:05 PM
GeorgeRud   Beautiful work!   Feb 16 2012, 09:52 PM
racerbvd   :shock1: WOW[:shock1: :shock1:   Feb 17 2012, 03:39 PM
Steve   Nice job, but I am curious why you need the early ...   Feb 18 2012, 11:20 AM
914dave   Nice job, but I am curious why you need the early ...   Feb 18 2012, 05:09 PM
Steve   Nice job, but I am curious why you need the early...   Feb 18 2012, 06:42 PM
914dave   Steve, I hear what you're saying about the co...   Feb 19 2012, 09:38 AM
Steve   I'm also looking forward to not having to ...   Feb 19 2012, 11:50 AM
- Lo-Fi Version Time is now: 12th March 2026 - 07:43 PM
