malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I am usually good to measure twice and cut once. Not sure why I messed this one up.
I have spent much time and a few dollars rebuilding this engine, so I wanted to be able to monitor it. Nothing too fancy or expensive, just some VDO gauges. I guess it is a little late now, but let me ask. Where can I put an oil pressure sensor that is 3 times as tall and twice as round as the OEM idiot light sender? The distributor gets in the way damn it. I can get it installed, but I lose some range of motion for the distributor. Then there's the cooling tin issue. My engine is assembled so, if the answer is to drill and tap somewhere else, that option is out. Somewhere online I saw an aluminum block that mounts to the oil filter attachment, then the oil filter screws into that. That block has 3 or 4 tapped holes to mount stuff. Where did I see that? And would it give me decent pressure? What can I do? Clark Picture of the VDO monster ![]() And the OEM version ![]() |
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I used a paintball hose. They come in different lengths. I made a bracket that attached to one of the case perimeter bolts. That way, I didn't need to use a separate groound wire.
Lo-Fi Version | Time is now: 19th July 2025 - 05:36 PM |
