Wrist Pin Removal, What's the Trick |
aharder |
Jan 11 2012, 07:48 PM
Advanced Member Group: Members Posts: 4,413 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
I'm replacing Rings and want to remove the pistons from the rods without splitting the case.
Are these wrist Pins suppose to be Butt Hole Tight (IMG:style_emoticons/default/confused24.gif) It's like it will take a Freaking Press to remove them (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) What's the trick to these little bitches that don't want to move (IMG:style_emoticons/default/screwy.gif) Oh Yea, the clips are rmoved (IMG:style_emoticons/default/biggrin.gif) |
Cap'n Krusty |
Jan 12 2012, 06:28 PM
I use a slide hammer and a 10mm T1 head stud with a 15mm wrench size nut on the end. You can't push one of the pins out because it hits the case flange where the tranny bolts up. I see no reason why you can't do that, and it's my opinion you're not gonna hurt the rod bearing. If you're worried about that, have a strong friend hold the piston while you extract the pin. I generally pull the rods anyway, checking them for size and adherence to specs, and replace the wrist pin bushings. New rod bearings are a part of that process.
The Cap'n |
Lo-Fi Version | Time is now: 10th June 2024 - 12:21 AM |
