flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,817 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
For a while now, my 914 has had an issue with smoke entering the cabin. Here are all of the clues, can somebody help me figure out what is going on?
At first, I thought it was electrical, but I'm fairly certain it's not - Amp gauge stays normal, all electrical components on the car work properly, and it doesn't smell like an electrical short. My next thought was that either there's an exhaust leak inside the SSHEs, or oil has dripped inside the HE shells and revving the engine heats it up enough to burn. But I'm skeptical of this because the problem seems totally unaffected by the position of the heat lever... would expect it to be worse when the heat lever is pulled, but it's not. Another clue: Yesterday I revved in first gear pulling into a gas station. Smoke from the dash. Pulled the front trunk release to fill the tank and saw a bit of smoke wafting from under the front trunk, through the gap at the edge of the trunklid. So I'm starting to think it's HVAC related. Final clue: I noticed yesterday that my charcoal canister (stock location for a '74, on top of the fuel tank on the driver's side) seems to weep a tiny amount of fuel. Thinking this is totally unrelated, but not certain. Given the leaky charcoal canister, I might take this opportunity to pull the fuel tank (have never done so in 2+ years of ownership), then pull and clean out the HVAC box... |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,737 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Valve cover gasket is leaking onto HE
Lo-Fi Version | Time is now: 11th July 2025 - 11:57 AM |
