> Installing poly bronze trailing arm bushings
sixaddict
post Jan 16 2012, 09:58 PM
Any words of wisdom. THX
Eric_Shea
post Jan 16 2012, 11:52 PM
PMB Performance
1. Check the zerks. I believe they finally switched to a 6x1 zerk which is a good thing. If not, get some because the 5x.8 they were using is too delicate in my book and they can easily snap off when installing (most want to push it to get the angle where they want it).
2. I personally never mess around with the 1/64th bit as suggested in the instructions. IMO its more than OK to simply drill through. The resulting hole is not much larger than the grease groove inside. That tiny bit will just break.
3. Use blue painters tape and mark your zerk locations as per instructions. Have a set of digital calipers available and double check your measurements. They are correct in the instructions. Spot on. I think it comes out to .973??? Measure from the top of the bushing and mark it on the tape.
4. Use a metal punch to make certain your drill gets started properly.
5. Use a drill press if you can. Tip: Install your hubs last, it helps with maneuverability in and around the press (if you go that route). A press will help keep the hole straight in the barrel.
6. Debur the inside with a fine rat tail.
Check your fitment because the bronze will not lie. They may bind a tad. If you can get the shaft through it by hand you should be fine, especially after you lube them up. If not, you'll probably need a new arm which is why you should check that before you drill. Again, a little binding is OK, remember, you'll have a 2000lb car on them.
Hope that helps. I've done a boatload of these.
phillstek
post Jan 17 2012, 12:38 AM
QUOTE(Eric_Shea @ Jan 17 2012, 04:52 PM) *
I snapped one of mine just like that. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/headbang.gif)
phil
- Lo-Fi Version Time is now: 2nd April 2026 - 09:04 PM
