| sixaddict |
Jan 16 2012, 09:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Any words of wisdom. THX
| Eric_Shea |
Jan 16 2012, 11:52 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
1. Check the zerks. I believe they finally switched to a 6x1 zerk which is a good thing. If not, get some because the 5x.8 they were using is too delicate in my book and they can easily snap off when installing (most want to push it to get the angle where they want it).
2. I personally never mess around with the 1/64th bit as suggested in the instructions. IMO its more than OK to simply drill through. The resulting hole is not much larger than the grease groove inside. That tiny bit will just break. 3. Use blue painters tape and mark your zerk locations as per instructions. Have a set of digital calipers available and double check your measurements. They are correct in the instructions. Spot on. I think it comes out to .973??? Measure from the top of the bushing and mark it on the tape. 4. Use a metal punch to make certain your drill gets started properly. 5. Use a drill press if you can. Tip: Install your hubs last, it helps with maneuverability in and around the press (if you go that route). A press will help keep the hole straight in the barrel. 6. Debur the inside with a fine rat tail. Check your fitment because the bronze will not lie. They may bind a tad. If you can get the shaft through it by hand you should be fine, especially after you lube them up. If not, you'll probably need a new arm which is why you should check that before you drill. Again, a little binding is OK, remember, you'll have a 2000lb car on them. Hope that helps. I've done a boatload of these. |
| phillstek |
Jan 17 2012, 12:38 AM
Member ![]() ![]() Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
1. Check the zerks. I believe they finally switched to a 6x1 zerk which is a good thing. If not, get some because the 5x.8 they were using is too delicate in my book and they can easily snap off when installing (most want to push it to get the angle where they want it). I snapped one of mine just like that. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/headbang.gif) phil |
| Elliot Cannon |
Jan 17 2012, 10:38 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
1. Check the zerks. I believe they finally switched to a 6x1 zerk which is a good thing. If not, get some because the 5x.8 they were using is too delicate in my book and they can easily snap off when installing (most want to push it to get the angle where they want it). I snapped one of mine just like that. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/headbang.gif) phil I broke two of them. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
| strawman |
Jan 17 2012, 07:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 891 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California
I broke two of them. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Me, too! I upsized 'em instead of putting the little buggers back in... |
sixaddict Installing poly bronze trailing arm bushings Jan 16 2012, 09:58 PM
Socalandy I'll be watching this as its in my plans!... Jan 16 2012, 10:11 PM
Krieger After I installed the bushing in the arm and put a... Jan 17 2012, 08:47 AM
tradisrad McMarks suggestion on removing the old bushings wa... Jan 17 2012, 09:42 AM
nsr-jamie Are you guys talking about the Elephant Racing one... Jan 18 2012, 07:23 AM
pcar916
I just bought those along with the front and plan... Jan 24 2012, 03:04 PM
Eric_Shea Yes. Jan 18 2012, 10:10 AM
sixaddict Great help all.....Everyone helped me not break wh... Jan 24 2012, 02:25 PM
Racing916 The threads for the grease fittings were different... Jan 24 2012, 04:22 PM
scotty b
The threads for the grease fittings were differen... Jan 24 2012, 10:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:04 PM |
