> Testing engine on run stand, Need help with setup
mikea100
post Jan 9 2012, 08:28 PM
Yesterday, with some help from my 2 boys, I got my '76 2.0 short block on the engine run stand. I need help setting it up. It's late 2.0, complete, all stock, EFI. I'm looking for any info, any help at all. I've read few dozen threads about engine stands, but most of them deal with yokes, adapters and such. I need help with wiring and actually test running the engine. If local guys can stop by this long weekend and land me a hand, you'd really do me a solid and I'll return the favor. I'll serve beer of your choice. (IMG:style_emoticons/default/beerchug.gif)
Thanks,
Mike
mikea100
post Jan 17 2012, 11:26 PM
First of, please be patient with me as I'm new at this and will ask for help.
I'm just going to go down the list. Solenoid (starter) has a heavy black wire (probably gauge 4) going to the battery + terminal. Where do I connect the power from switch? I'm assuming that it goes to light spade connector, correct?
mikea100   Testing engine on run stand   Jan 9 2012, 08:28 PM
Jeffs9146   It looks like you used nails or screws to hold tha...   Jan 9 2012, 09:24 PM
mikea100   It looks like you used nails or screws to hold th...   Jan 9 2012, 10:35 PM
RobW   What are you testing?   Jan 9 2012, 10:40 PM
mikea100   What are you testing? I just want to make sure t...   Jan 10 2012, 05:56 PM
Jeffs9146   I have some engine run stand exhaust that you migh...   Jan 10 2012, 06:22 PM
windforfun   Too bad Thomas isn't around to help. Sorry, I...   Jan 10 2012, 07:24 PM
Vacca Rabite   Actually, as long as you have the engine like that...   Jan 10 2012, 08:42 PM
mikea100   Actually, as long as you have the engine like tha...   Jan 10 2012, 09:26 PM
Vacca Rabite   I used the cheapest push button starter switch I c...   Jan 10 2012, 10:49 PM
jcd914   Add to your engine stand a place to hang your FI c...   Jan 11 2012, 02:49 AM
jcd914   The connector pin list I posted was inputs/outputs...   Jan 18 2012, 05:48 PM
mikea100   First of, please be patient with me as I'm new...   Jan 17 2012, 11:26 PM
dlee6204   Correct   Jan 18 2012, 12:09 PM
Dave_Darling   You'll need power to the coil. You'll nee...   Jan 18 2012, 12:28 PM
mikea100   I'm having trouble with this seemingly easy ta...   Jan 22 2012, 06:28 PM
Dave_Darling   The battery + should connect to the big post on th...   Jan 22 2012, 07:14 PM
mikea100   The battery + should connect to the big post on t...   Jan 23 2012, 10:54 AM
mikea100   The battery + should connect to the big post on t...   Jan 24 2012, 02:02 PM
PRS914-6   Posted on this thread as well: Ready for break in-...   Jan 22 2012, 09:04 PM
mikea100   Posted on this thread as well: Ready for break in...   Jan 23 2012, 11:05 AM
ape914   just put it in the car, 914's are blessed with...   Jan 23 2012, 12:54 PM
Dave_Darling   The decimals should be the thickness of the conduc...   Jan 24 2012, 03:57 PM
mikea100   I traced most of the 12 pin connections, but some ...   Jan 26 2012, 11:30 PM
Dave_Darling   The connections vary a little from year to year. ...   Jan 27 2012, 04:48 PM
mikea100   Thanks Dave. I finally got a compression gauge and...   Jan 28 2012, 10:41 PM
Dave_Darling   Intakes are the middle valves, exhausts are the ou...   Jan 28 2012, 11:14 PM
mikea100   I did the valve adjustment today and remeasured. I...   Jan 29 2012, 08:26 PM
Vacca Rabite   I did the valve adjustment today and remeasured. ...   Jan 30 2012, 06:22 PM
Jon Fernandes   Mike, I may have an MPS accessible in my mess of a...   Jan 30 2012, 11:18 AM
mikea100   Mike, I may have an MPS accessible in my mess of ...   Jan 30 2012, 12:30 PM
ruddyboys   I am going to try this in a few weeks. 1st questio...   Jan 30 2012, 04:09 PM
mikea100   I am going to try this in a few weeks. 1st questi...   Jan 31 2012, 09:35 AM
nathansnathan   Also you want to make sure all the spark plugs are...   Jan 30 2012, 07:06 PM
mikea100   The engine was cold, I don't believe that it h...   Jan 30 2012, 08:04 PM
ruddyboys   The black purple goes to the tach, so I wont be ne...   Jan 31 2012, 03:08 PM
Dave_Darling   There is no purple wire on the coil that I am awar...   Jan 31 2012, 05:26 PM
mikea100   I have great news to report. I did as Nathan sugge...   Jan 31 2012, 09:21 PM
mikea100   I've had no luck in getting this engine runnin...   Feb 24 2012, 10:33 PM
Al Meredith   Whenever I build an engine I run it on my engine s...   Feb 25 2012, 10:27 AM
Prospectfarms   Yesterday, with some help from my 2 boys, I got m...   Feb 25 2012, 10:43 AM
Tom   Did you hook up your relay board? That is needed t...   Feb 25 2012, 10:57 AM
mikea100   Tom, The relay board is hooked up, however, I have...   Feb 25 2012, 07:08 PM
Tom   It looks like you are not getting power to the ECU...   Feb 26 2012, 07:46 AM
Prospectfarms   It looks like you are not getting power to the EC...   Feb 26 2012, 09:37 AM
Tom   Wow Stuart, Those are great diagrams. Thanks ...   Feb 26 2012, 10:09 AM
mikea100   Thank you guys, those diagrams are great. My alter...   Feb 27 2012, 08:05 PM
Tom   mikea100, Pins 12 and 14 are the power to the ...   Feb 27 2012, 08:54 PM
- Lo-Fi Version Time is now: 14th November 2025 - 08:14 PM
