| Black914_4 |
Jan 19 2012, 07:11 AM
Member ![]() ![]() Group: Members Posts: 272 Joined: 11-January 12 From: AR Member No.: 13,994 Region Association: South East States |
Would someone mind explaning how the heater controls work please.
I have the '74 914 with the 2.0. I need to know what levers does what. ie. - middle lever moved to left does ..., to the right does.., bottom lever moved to left or right does... Thanks |
| Dave_Darling |
Jan 19 2012, 12:42 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
And far right on the top lever should turn on the fresh air blower. If the fan motor still works, that is.
--DD |
| flipb |
Jan 19 2012, 01:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,874 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region
And far right on the top lever should turn on the fresh air blower. If the fan motor still works, that is. --DD I always thought that the top lever was sort of a rheostat for the vent fan. Left=off, middle = varying degrees of on; Right = blowing full blast (which isn't much!) Am I mistaken? I vaguely remember testing it with the engine off (ignition turned on) and listening to the sound of the fan at different settings. |
2xs performance Heater Control question Jan 19 2012, 07:11 AM
flipb This is from memory, so others please correct me i... Jan 19 2012, 08:19 AM
Dave_Darling I always thought that the top lever was sort of a ... Jan 19 2012, 04:03 PM
mrholland2 How "needed" is the fresh air part? Is i... Jan 19 2012, 05:00 PM
Cevan Top lever controls the speed of the fresh air fan.... Jan 19 2012, 01:55 PM
Dave_Darling Only you can tell how "needed" it is. I... Jan 19 2012, 06:32 PM
GeorgeRud It's nice to be able to use both the fresh and... Jan 19 2012, 09:23 PM
johannes
It's nice to be able to use both the fresh an... Jan 20 2012, 08:00 AM
2xs performance I appriecate the help. That was what I needed to k... Jan 20 2012, 06:54 AM
partwerks You'd think that with the squirrel cage helper... Jan 20 2012, 08:05 AM
442nd914s Hope you guys don't mind if I piggy back off o... Apr 14 2013, 08:25 PM
Dave_Darling
What makes the defrost lamp cover to illuminate?
... Apr 14 2013, 10:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 11:47 PM |
