jporsche914 |
Member ![]() ![]() Group: Members Posts: 149 Joined: 9-March 04 From: colorado, springs Member No.: 1,769 ![]() |
I have a 1972 1.7L 914 and i want a shorter more direct throw. I have been reading a couple of posts about the rennshift. It seems to be a great shifter for the 914 but it is a bit pricey compared to the Weltmeister short shift kit. Would the cheaper Weltmeister shifter still feel better than stock with all the bushing replaced?? They say that the throw is reduced 30 percent which is the same as the rennshift. Do you guys think it is worth going with the Rennshifter or do you think i would be happier with the Weltmeister shifter.
Thanks |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Another vote against the Weltmeister. I had one in my tailshifting car when I bought it, and found it made just pulling it into first gear a real bear against the centering springs with a lever that was shorter and thus farther away from me. I sourced a stock lever and fit that, with new bushings front to back. I find this quite acceptable for now. I'd keep the stock shifter and replace ALL of the bushings in your linkage before spending any money on any shifter. You need to so this, anyway, even if you decided to go for the Rennshift. You may find just rebushing is enough for you.
Lo-Fi Version | Time is now: 11th July 2025 - 11:51 AM |
