jporsche914 |
Member ![]() ![]() Group: Members Posts: 149 Joined: 9-March 04 From: colorado, springs Member No.: 1,769 ![]() |
I have a 1972 1.7L 914 and i want a shorter more direct throw. I have been reading a couple of posts about the rennshift. It seems to be a great shifter for the 914 but it is a bit pricey compared to the Weltmeister short shift kit. Would the cheaper Weltmeister shifter still feel better than stock with all the bushing replaced?? They say that the throw is reduced 30 percent which is the same as the rennshift. Do you guys think it is worth going with the Rennshifter or do you think i would be happier with the Weltmeister shifter.
Thanks |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(mwyatt @ May 10 2004, 11:11 AM) does the device make any other appreciable difference (excluding appearance)? IMO - yes, Bigtime -- especially with the reverse lockout. the spring centering makes traffic shifting completely intuitive. to shift from first to second, just move the lever up - the spring takes the lever right into the 2/3 plane. to upshift into 3rd, just pull the lever back. you do have to press against the spring to get up into 4th - but you adapt in a flash. downshifting to 3rd, you just pull back and let the spring find 3rd for you. there is no slop - the ball joint pivot in the shifter is tight. i haven't tagged reverse coming up out of 1st since i installed the product, and now that i've retrofitted the lockout, i know i won't be going there accidentally under stress. (you can, however, still shift from reverse to first if you need to - rocking out of a hole, for instance. crisp, precise shifting is a big part of the overall sports-car driving experience for me, and this product makes it happen. it is not a pill cure for sloppy mechanisms and floppy driveline mounts; you have to fix those first if they're worn. |
Lo-Fi Version | Time is now: 11th July 2025 - 10:25 AM |
