| stugray |
Oct 18 2010, 02:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have rebuilt a type IV a couple of times, but I was young & naive.
This will be a 2.0L with stock FI for vintage racing. 1 - How do I hook up the stock fuel pump line(s) to a fuel cell? 2 - are there any Cams other than the stock one that will give me increased performance while still using the stock FI? 3 - What compression ratio should I target? I am working that step right now - CC'ing the heads & setting the deck height. 4 - The CAM thrust bearing has just one side with the thrust plate on it. If I recall, when I upgraded my last 914, the guy at the performance shop gave me TWO with the thrust bearing on it (one for each side). Should I be looking for those? 5 - After splitting the case, there were 2 or 3 "bumps" that needed a little "flattening out" with a file. Can the case be damaged by trying to clean up the nasty spots, or is there a way for me to make sure to get it right? I imagine that the only thing I could do would be to remove all the studs and rub each side over some sandpaper taped down to a very flat surface... Any help is appreciated. Stu |
| stugray |
Jan 23 2012, 08:13 PM
Ok, so what I am learning here is that nobody has ever had stock heads cut to ~10:1 compression ratio assuming stock pistons/stroke & deck height.....
RRRIIIIIGGHHHT wink... wink... (IMG:style_emoticons/default/lol-2.gif) SO what is the secret handshake??? I had one guy tell me that he had built at least two 914 SCCA engines that WON THE SCCA championship. Yet he told me to run 100% stock compression with webers... In Colorado...... How hard-ass do you have to be to not share this information? (IMG:style_emoticons/default/blink.gif) If I could machine them myself, I would CC them at every thousandth and make a nice lookup table. Not rocket science, but not easy to calculate chamber volume from a cast head in advance. On another thread people posted stock CR calculators, but they do not factor in the shape of the type-IV combustion chamber and what removing X results in Y of CR change. Stu |
| jaxdream |
Jan 24 2012, 09:12 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Ok, so what I am learning here is that nobody has ever had stock heads cut to ~10:1 compression ratio assuming stock pistons/stroke & deck height..... RRRIIIIIGGHHHT wink... wink... (IMG:style_emoticons/default/lol-2.gif) SO what is the secret handshake??? I had one guy tell me that he had built at least two 914 SCCA engines that WON THE SCCA championship. Yet he told me to run 100% stock compression with webers... In Colorado...... How hard-ass do you have to be to not share this information? (IMG:style_emoticons/default/blink.gif) If I could machine them myself, I would CC them at every thousandth and make a nice lookup table. Not rocket science, but not easy to calculate chamber volume from a cast head in advance. On another thread people posted stock CR calculators, but they do not factor in the shape of the type-IV combustion chamber and what removing X results in Y of CR change. Stu Stu , since you have the heads that you want to run ,try flycutting the edge ( .010, .020,etc. ) of the plate to step it down into the chamber for CCing to get an idea of what possibly a flycut to the head might produce . It would probably be approximate , but would give an idea of a say what a flycut of the cut to the plate might give . It is cheaper to cut the plastic plate than cutting the heads several times to get to a target number and yes it might not be exact , but give some kind of idea of what could be a possible one cut to the heads might produce. Shim cylinders from there . Good Luck to ya .... Jack |
stugray Engine rebuild, a few questions Oct 18 2010, 02:40 PM
Cupomeat Ok, I'll give it a go and I am sure you will h... Oct 18 2010, 03:01 PM
Bleyseng 2. The absolute best cams for Djet FI are Raby cam... Oct 19 2010, 04:02 AM
stugray Cupomeat,
1 - Still trying to find a legal fuel c... Oct 19 2010, 11:06 AM
Cupomeat
Cupomeat,
1 - Still trying to find a legal fuel ... Oct 19 2010, 11:15 AM
ArtechnikA
1 - Still trying to find a legal fuel cell. It ne... Oct 19 2010, 11:52 AM
Jake Raby
Understand this:
My package INCLUDES ALL the ite... Oct 19 2010, 01:01 PM
stugray ArtechnikA,
Thanks for all the comments
"T... Oct 19 2010, 01:30 PM
ArtechnikA
...there are HUNDREDS of choices out there and ve... Oct 19 2010, 06:13 PM
stugray Jake Raby,
Thanks for the detailed reply.
I have ... Oct 19 2010, 01:33 PM
Jake Raby My team is here to help you, don't worry about... Oct 19 2010, 06:42 PM
stugray Thanks again for the comments.
Here are some pics... Oct 20 2010, 07:02 AM
Jake Raby Get rid of those sodium filled exhaust valves... Oct 20 2010, 07:45 AM
stugray Ok, Jake.
I have new valves and purchased your ra... Jan 21 2012, 12:53 PM
Jake Raby
You'd waste your time.. All stock chambers ar... Jan 23 2012, 10:38 PM
stugray Ok Next update:
I have the European Motor Works, ... Aug 26 2012, 06:26 PM
cgnj Hi,
60 cc's is what I got on my rebuilt stock... Aug 26 2012, 07:44 PM
Valy Bringing the heads to 48cc will probably remove th... Aug 26 2012, 08:23 PM
stugray Thanks for the tips.
I will target 50cc if I can ... Aug 27 2012, 12:00 AM
Valy You need big washers to spread the load.
I got min... Aug 27 2012, 10:50 AM
Racer Chris Stu,
A tight deck is much better for efficient com... Aug 27 2012, 11:25 AM
Dave_Darling Are the 2.0 heads the ones where it is easy to bre... Aug 27 2012, 03:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 09:27 PM |
