| ruby914 |
Jan 24 2012, 12:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
I am now installing my flares and hoped to use very little body filler.
I located the flares, sheet metal screwed, marked off with a sharpie, started the cut with a cutoff wheel, finished with a body saw keeping tabs at the screws, removed paint on both sides, tacked between the tabs and tacked until I could cut off the tabs with a good fit. I continued to tack until about every 3/4". Never ran a weld over 1/2" at a time. I tried to move my welds around to reduce heat. I was happy with my work feeling the flare had more die marks than warping from my welding. So standing back I see something I am not sure I like. This may not just be a welding question but what a factory 914 GT looks like? What I am seeing is, before the flare, flares out, the fender pulls in. I see this mostly in the back of the front flare. I have only cut the 2nd front fender off and I see the remaining fender has pulled in before any welding. This is a first time for me and I am sure there is a lot to be learned with many years in the business. So is the pulling in the norm? In all the beautiful photos of clean lines, how much body filler is reasonable. Is there ways to limit this from the start or is this normally fixed with hammer and dolly as you go? I will try to add a photo of where it is pulling in. Thanks Attached thumbnail(s) |
| scotty b |
Jan 24 2012, 08:12 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Your fender most likely was already a little buckled, or you got it a bit hot when welding and sucked in. These flares are not a " perfect " fit but are a damn good start. The way you proceeded is a god way to go. I always keep my hammer and dolly by my side and work the seam as I am welding. I also do not run beads. I just connect spot/tack welds. This way I can get it set in place, then work the gap shut, add another tack, work the gap back together etc.
ruby914 Installing flares Jan 24 2012, 12:31 PM
dlestep spend some hours staring at this guys work...for c... Jan 24 2012, 02:04 PM
SirAndy The factory used full fenders.
Nope. They butt-wel... Jan 24 2012, 08:56 PM
ruby914
spend some hours staring at this guys work...for ... Jan 25 2012, 02:07 AM
ruby914
Your fender most likely was already a little buck... Jan 25 2012, 03:06 AM
pdlightning
[quote name='scotty b' post='1611187' date='Jan 2... Jan 25 2012, 05:29 AM
gothspeed When I get around to installing mine, I want to kn... Jan 24 2012, 08:39 PM
mepstein "The factory used full fenders." - I don... Jan 24 2012, 08:51 PM
scotty b Early 930's were welded on, on all four corner... Jan 24 2012, 08:58 PM
rick 918-S I agree with Scotty, I can see body filler in a cr... Jan 24 2012, 09:21 PM
jmill Lots and lots of little spot welds. Tack around t... Jan 24 2012, 09:47 PM
bulitt Here is a thread documenting many prior threads on... Jan 25 2012, 07:04 AM
ruby914
Here is a thread documenting many prior threads o... Jan 25 2012, 10:45 AM
dlestep I believed that M471 option was a full fender, did... Jan 25 2012, 09:50 AM
gothspeed
Early 930's were welded on, on all four corne... Jan 25 2012, 10:01 AM
Madswede
I would still like to see more pictures fo that b... Jan 25 2012, 10:40 AM
ruby914 One more on how I did it. Jan 25 2012, 10:52 AM
gothspeed Thanks for posting Ruby :beer2: !! Jan 25 2012, 11:21 AM
RiqueMar Might have already covered this, but did you have ... Jan 25 2012, 01:50 PM
ruby914
Might have already covered this, but did you have... Jan 25 2012, 02:35 PM
McMark I position the flares to match the narrow body whe... Jan 25 2012, 06:26 PM
sean_v8_914 GT flare mysteries:
im about to get into a flare i... Jan 26 2012, 10:26 AM
sean_v8_914 I see that even teh 911 flare has that flat secti... Jan 26 2012, 10:29 AM
mepstein Remake the mold? It won't happen. Jan 26 2012, 10:43 AM
sean_v8_914 sometimes a correction is possible in the dies...y... Jan 26 2012, 10:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:12 PM |
