> Installing flares, how good is good, how would Scott B do it?
ruby914
post Jan 24 2012, 12:31 PM
I am now installing my flares and hoped to use very little body filler.
I located the flares, sheet metal screwed, marked off with a sharpie, started the cut with a cutoff wheel, finished with a body saw keeping tabs at the screws, removed paint on both sides, tacked between the tabs and tacked until I could cut off the tabs with a good fit. I continued to tack until about every 3/4". Never ran a weld over 1/2" at a time. I tried to move my welds around to reduce heat.
I was happy with my work feeling the flare had more die marks than warping from my welding.
So standing back I see something I am not sure I like.
This may not just be a welding question but what a factory 914 GT looks like?
What I am seeing is, before the flare, flares out, the fender pulls in. I see this mostly in the back of the front flare. I have only cut the 2nd front fender off and I see the remaining fender has pulled in before any welding.
This is a first time for me and I am sure there is a lot to be learned with many years in the business.
So is the pulling in the norm? In all the beautiful photos of clean lines, how much body filler is reasonable.
Is there ways to limit this from the start or is this normally fixed with hammer and dolly as you go?
I will try to add a photo of where it is pulling in.
Thanks
jmill
post Jan 24 2012, 09:47 PM
Green Hornet
Lots and lots of little spot welds. Tack around the radius and then spot in between the spots. Keep going slowly until you have a spot everywhere.
ruby914   Installing flares   Jan 24 2012, 12:31 PM
dlestep   spend some hours staring at this guys work...for c...   Jan 24 2012, 02:04 PM
SirAndy   The factory used full fenders. Nope. They butt-wel...   Jan 24 2012, 08:56 PM
ruby914   spend some hours staring at this guys work...for ...   Jan 25 2012, 02:07 AM
scotty b   Your fender most likely was already a little buckl...   Jan 24 2012, 08:12 PM
ruby914   Your fender most likely was already a little buck...   Jan 25 2012, 03:06 AM
pdlightning   [quote name='scotty b' post='1611187' date='Jan 2...   Jan 25 2012, 05:29 AM
gothspeed   When I get around to installing mine, I want to kn...   Jan 24 2012, 08:39 PM
mepstein   "The factory used full fenders." - I don...   Jan 24 2012, 08:51 PM
scotty b   Early 930's were welded on, on all four corner...   Jan 24 2012, 08:58 PM
rick 918-S   I agree with Scotty, I can see body filler in a cr...   Jan 24 2012, 09:21 PM
jmill   Lots and lots of little spot welds. Tack around t...   Jan 24 2012, 09:47 PM
bulitt   Here is a thread documenting many prior threads on...   Jan 25 2012, 07:04 AM
ruby914   Here is a thread documenting many prior threads o...   Jan 25 2012, 10:45 AM
dlestep   I believed that M471 option was a full fender, did...   Jan 25 2012, 09:50 AM
gothspeed   Early 930's were welded on, on all four corne...   Jan 25 2012, 10:01 AM
Madswede   I would still like to see more pictures fo that b...   Jan 25 2012, 10:40 AM
ruby914   One more on how I did it.   Jan 25 2012, 10:52 AM
gothspeed   Thanks for posting Ruby :beer2: !!   Jan 25 2012, 11:21 AM
RiqueMar   Might have already covered this, but did you have ...   Jan 25 2012, 01:50 PM
ruby914   Might have already covered this, but did you have...   Jan 25 2012, 02:35 PM
McMark   I position the flares to match the narrow body whe...   Jan 25 2012, 06:26 PM
sean_v8_914   GT flare mysteries: im about to get into a flare i...   Jan 26 2012, 10:26 AM
sean_v8_914   I see that even teh 911 flare has that flat secti...   Jan 26 2012, 10:29 AM
mepstein   Remake the mold? It won't happen.   Jan 26 2012, 10:43 AM
sean_v8_914   sometimes a correction is possible in the dies...y...   Jan 26 2012, 10:51 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:46 PM
