| jules2c |
Jan 24 2012, 08:39 PM
Newbie ![]() Group: Members Posts: 16 Joined: 15-January 12 From: Milton Keynes Member No.: 14,010 Region Association: None |
I do not know if anyone has done this before it just seemed a sensible idea at the time. The car had all the usual disasters and a few novel ones made by the factory! This may offend purists but it had been rearly abused and I could not believe the crazy design of just about everything. It was a 74 2.0 4, it has been stripped of most parts and I have been slowly welding it back to a solid structure.
The doors have very good alignment and operate as I assume they should but the roof will not align at the rear being flush on the right side and sticking out about 4 to 5mm on the left. I straightened the left long which was about 4 to 5mm high in the middle this seemed to make no difference. The fiberglass roof I assume is accurate as I have not come across fiberglass warping I just dont know. If you have any ideas please let me know. Has anyone mounted a rad in the back of the car using the engine deck as the outlet feeding from the floor? More metal abuse tomorrow and the the next etc etc. |
| rick 918-S |
Jan 24 2012, 11:04 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,279 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I do not know if anyone has done this before it just seemed a sensible idea at the time. The car had all the usual disasters and a few novel ones made by the factory! This may offend purists but it had been rearly abused and I could not believe the crazy design of just about everything. It was a 74 2.0 4, it has been stripped of most parts and I have been slowly welding it back to a solid structure. The doors have very good alignment and operate as I assume they should but the roof will not align at the rear being flush on the right side and sticking out about 4 to 5mm on the left. I straightened the left long which was about 4 to 5mm high in the middle this seemed to make no difference. The fiberglass roof I assume is accurate as I have not come across fiberglass warping I just dont know. If you have any ideas please let me know. Has anyone mounted a rad in the back of the car using the engine deck as the outlet feeding from the floor? More metal abuse tomorrow and the the next etc etc. First things first! (IMG:style_emoticons/default/welcome.png) There have been many different conversions done here. There was a subaru conversion done where the builder placed the radiator just ahead of the engine. I saw this conversion. Although the work was quick and dirty the radiator cooled the engine just fine in that location. Here's a link to the 914 Info section. http://www.914world.com/specs/914info.php There are chassis diamensions there that may help you fix your chassis issue. If you can post photos that will help us understand what your up against. (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
jules2c Bluesport Retro Jan 24 2012, 08:39 PM
jules2c
I do not know if anyone has done this before it ... Jan 25 2012, 02:23 PM
jules2c Thanks for information, now to try again to upload... Jan 25 2012, 02:35 PM
ape914 i think a engien grill mounted radiator is a great... Jan 26 2012, 12:25 AM
dlo914
i think a engien grill mounted radiator is a grea... Jan 26 2012, 01:27 AM
jules2c Thanks for advice, I did not know it sucked from a... Jan 26 2012, 08:42 PM
jules2c Thanks for information, it always helps to not rei... Jan 26 2012, 08:53 AM
majkos Wow!
You're good !
You got some ski... Jan 26 2012, 05:41 PM
rohar If you mount a VW engine transverse with the stock... Jan 26 2012, 08:52 PM
jules2c Thanks for your thoughts, not sure about the VW tu... Jan 27 2012, 08:09 PM
geniusanthony I have no experience with that diesel, but have tw... Jan 27 2012, 07:55 PM
jcd914
I have no experience with that diesel, but have t... Jan 27 2012, 09:13 PM
rohar
[quote name='geniusanthony' post='1613122' date='... Jan 31 2012, 09:42 AM
geniusanthony That's good to know Jim. What is the engine co... Jan 28 2012, 08:46 AM
jules2c Have thought of tilting the next engine forward as... Jan 31 2012, 06:43 AM
Jon Fernandes Check out the TDIclub.com forums, there is a Conve... Jan 31 2012, 09:34 AM
jules2c That is correct, the use of the entire engine gear... Jan 31 2012, 02:06 PM
paroxysm How about a b5 tdi passat mounted longitudinal, or... Jan 31 2012, 06:29 PM
rohar Mounting a VW inline 4 (diesel or gas) longitudina... Feb 1 2012, 05:59 PM
paroxysm
Mounting a VW inline 4 (diesel or gas) longitudin... Feb 1 2012, 07:39 PM
jules2c Just thought this might be of interest, in the pho... Feb 2 2012, 10:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 10:18 AM |
