| ThePaintedMan |
Jan 24 2012, 12:20 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Hello all,
I've tried searching for this question, but haven't found anything definitive. Though its still a ways off, I am hoping to add the ol' RX-7 oil cooler up front, complete with a custom fiberglass valence on this '73 1.7. In the meantime, while I've got the motor sitting here in the driveway, I wanted to switch to the heavy-duty oil pump. I have heard this is a good idea with an oil cooler mounted a ways from the pump. I'll be using the sandwich adapter and keeping the stock cooler as well. My question is mostly pertaining to the relief valve inside the motor. Do you have to replace it if you use the type I pump? Will it dramatically increase oil pressure if you don't? Any help would be appreciated. Thanks! |
| Chris Hamilton |
Jan 25 2012, 10:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
Your stock 1.7 is overheating without a cooler? Have you checked the tins?
| ThePaintedMan |
Jan 25 2012, 10:39 PM
Your stock 1.7 is overheating without a cooler? Have you checked the tins? No, no. It ran fine when I had the motor in it. But its going to be running (hopefully) 14 hours at Sebring in August with Chumpcar. I'm sure it won't be the only one of my concerns, but its my biggest right now. I just am interested in putting it up front.. well, just 'cause. (IMG:style_emoticons/default/wink.gif) |
ThePaintedMan Type I Oil pump for front mounted oil cooler? Jan 24 2012, 12:20 AM
yeahmag From my personal experience I would suggest runnin... Jan 24 2012, 12:27 AM
ThePaintedMan Thanks Aaron!
I guess I should have clarifi... Jan 24 2012, 12:49 AM
yeahmag Yup. A 27mm is enough to do the job, but they are ... Jan 24 2012, 01:09 AM
ape914 if you block the filter relief valve, be sure to g... Jan 24 2012, 08:06 AM
Mark Henry Personally for your app I'd use the 30mm pump ... Jan 24 2012, 08:32 AM
sean_v8_914 and use longer studs in the case Jan 24 2012, 09:26 AM
ThePaintedMan Yikes,
This is a little more involved than I w... Jan 25 2012, 10:00 PM
Mark Henry
Yikes,
This is a little more involved than I ... Jan 25 2012, 11:08 PM
Cap'n Krusty I fail to see where you're getting the idea th... Jan 25 2012, 11:08 PM
ThePaintedMan
I fail to see where you're getting the idea t... Jan 25 2012, 11:31 PM
Chris Hamilton It's only going to overheat if there is someth... Jan 26 2012, 12:00 AM
ape914 stock 1.7's or 2.0 can run too hot with extend... Jan 26 2012, 12:16 AM
ThePaintedMan
stock 1.7's or 2.0 can run too hot with exten... Jan 26 2012, 12:58 AM
Racer Chris
180F should be a nice target temp for the su... Jan 26 2012, 09:26 PM
ape914
180F should be a nice target temp for the s... Jan 27 2012, 11:40 AM
Racer Chris
At a little past 210F the oil pressure take a... Jan 27 2012, 12:35 PM
ape914
At a little past 210F the oil pressure take ... Jan 27 2012, 03:44 PM
ThePaintedMan Okay, back to the original question... would the r... Jan 26 2012, 08:28 PM
yeahmag Need, no. Want to, yes. It's easy even with th... Jan 26 2012, 08:30 PM
ThePaintedMan
Need, no. Want to, yes. It's easy even with t... Jan 26 2012, 08:42 PM
ThePaintedMan
Need, no. Want to, yes. It's easy even with ... Jan 26 2012, 08:50 PM
Phil Plummer
[quote name='ThePaintedMan' post='1612539' date='... Feb 20 2012, 06:27 PM
yeahmag Those both solve different problems. Jan 26 2012, 08:53 PM
yeahmag The GB cover prevents too much pressure from enter... Jan 26 2012, 08:58 PM
Jake Raby I always highly recommend not mounting coolers up ... Jan 26 2012, 09:08 PM
ThePaintedMan Okay, just wanted to say thanks to everyone for th... Jan 26 2012, 10:47 PM
flash914 I'm newer to air cooled engines mostly I do LA... Jan 26 2012, 11:11 PM
Jake Raby Equip the engine with proper instrumentation and p... Jan 26 2012, 11:24 PM
SLITS I was running thru the desert on the hottest day o... Jan 27 2012, 02:18 PM
LotusJoe I've run my 914 in 6 LeMons races. Half with t... Jan 27 2012, 02:51 PM
Jake Raby Remember: Cooling the oil won't cool the heads... Jan 27 2012, 07:05 PM
ThePaintedMan This is great stuff guys! I think this will be... Jan 27 2012, 09:32 PM
mrbubblehead i used dakota digital gauges. the are suppose to b... Jan 27 2012, 09:42 PM
Mark Henry ThePaintedMan PM'ed me on FF oiling, thinking ... Jan 28 2012, 11:45 AM
ape914
ThePaintedMan PM'ed me on FF oiling, thinking... Jan 28 2012, 12:56 PM
ThePaintedMan I can wrap my head around FF oiling I think. But I... Jan 29 2012, 10:34 AM
Racer Chris You don't need a bigger oil pump.
You don... Jan 29 2012, 11:44 AM
Eric_Shea
Because you don't seem to want to take the a... Jan 29 2012, 11:54 AM
ThePaintedMan Eric,
I respect your opinion, along with all o... Jan 29 2012, 01:12 PM
yeahmag Please do some testing. I myself am not convinced ... Jan 29 2012, 01:47 PM
Racer Chris What kind of tires will you be running? What's... Jan 29 2012, 10:27 PM
Jake Raby Greater volume is required to build higher pressur... Jan 30 2012, 04:34 AM
ThePaintedMan Chris,
Tires are open, as long as they're ... Jan 30 2012, 10:00 AM
Racer Chris
Chris,
Tires are open, as long as they're... Jan 30 2012, 11:46 AM
ThePaintedMan Yeah, I'm starting to think that we'll be ... Jan 30 2012, 11:57 AM
Racer Chris 140 rear springs would be a good thing. You might ... Jan 30 2012, 12:44 PM
LotusJoe
140 rear springs would be a good thing. You might... Jan 30 2012, 03:55 PM
yeahmag I ran the Azenis with 180lb springs, 21mm torsion ... Jan 30 2012, 04:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 10:17 AM |
