> bilstein shock questions, my V8 is sagging
xsJerry
post Jan 25 2012, 12:31 PM
my recently purchased '75 5.7 is sagging in the rear, and I'm hoping someone can help me out. The clips are set to highest setting and it's still low, and when I jounce the rear end, there's no movement. here's my questions:
1. what do I have now, the coil diameter is roughly 3.625 (92 mm) X .47 (12 mm).
2. Renegade recommends 200# springs but only sells the coil over kit $350 or so. Where can I get springs for this shock? (IMG:style_emoticons/default/idea.gif)
Any advice would be much appreciated.
Thanks
sean_v8_914
post Jan 25 2012, 10:48 PM
Chingon 601
suspension is a system. Proper handling is a safety concern. I recommend taking the time to investigate. you already have heavy springs back there so what is wrong?
what torsions are up front?
are your gas charged Bilsteins blown?
are the top hats installed corrctly?
xsJerry
post Jan 25 2012, 11:45 PM
QUOTE(sean_v8_914 @ Jan 25 2012, 08:48 PM) *
So, it looks to you that those are heavy springs? Being a newbie, I'm not sure I can answer any of those questions. If I pull them off things may become clearer. considering the size of the tires, I don't think the front can drop w/o clearance issues. on a side note, with the car level, I may put 50 series tires on it instead of 60s.
The car actually handles very well as is, but I don't have anything to compare it to.
also, as stated earlier, Automotion carries 200# springs for the 914, but they couldn't confirm they would fit on the Bilsiens (they are after marked right?).
thanks
xsJerry   bilstein shock questions   Jan 25 2012, 12:31 PM
Andyrew   Show some pictures of the "sagging" rear...   Jan 25 2012, 12:47 PM
jmmotorsports   Pelican Parts, Performance Products. AutoAtlanta, ...   Jan 25 2012, 12:48 PM
xsJerry   Pelican Parts, Performance Products. AutoAtlanta,...   Jan 25 2012, 02:12 PM
bulitt   Automotion also carries 200lb springs.   Jan 25 2012, 02:14 PM
jmmotorsports   Automotion also carries 200lb springs. 180...   Jan 25 2012, 02:53 PM
sean_v8_914   suspension is a system. Proper handling is a safet...   Jan 25 2012, 10:48 PM
xsJerry   suspension is a system. Proper handling is a safe...   Jan 25 2012, 11:45 PM
sean_v8_914   have those springs been cut? I think stacking weig...   Jan 25 2012, 10:51 PM
ChrisNPDrider   more pics would help Most 914s look low in back, t...   Jan 25 2012, 11:47 PM
xsJerry   more pics would help Most 914s look low in back, ...   Jan 26 2012, 11:59 AM
xsJerry   it's also about 1/4" lower on the right s...   Jan 26 2012, 12:03 PM
Rand   it's also about 1/4" lower on the right ...   Jan 26 2012, 12:08 PM
SirAndy   it's also about 1/4" lower on the right s...   Jan 26 2012, 01:11 PM
dlo914   If ya eventually don't like the bilsteins, how...   Jan 26 2012, 01:29 AM
Eric_Shea   :agree: lower the front. :D I like the tires tho...   Jan 26 2012, 12:31 PM
Andyrew   Those are some tall tires... I agree with the bo...   Jan 26 2012, 08:40 PM
ppetion   Those are some tall tires... I agree with the b...   Jan 27 2012, 12:25 AM
computers4kids   Those are some tall tires... I agree with the ...   Jan 27 2012, 09:18 AM
xsJerry   Thanks all. I havn't seen any rust at all on t...   Jan 27 2012, 01:06 PM
nsr-jamie   Its easy to lower the front end. Also you may want...   Jan 26 2012, 09:45 PM
sean_v8_914   rt rear is low and has more neg camber. everyone e...   Jan 26 2012, 09:57 PM
Rand   Lowering the front is super quick and easy by just...   Jan 27 2012, 01:20 PM
KELTY360   Lowering the front is super quick and easy by jus...   Jan 28 2012, 12:40 AM
Rand   Here's a thread with bad suspension console ea...   Jan 27 2012, 01:22 PM
- Lo-Fi Version Time is now: 9th June 2026 - 10:15 AM
