| xsJerry |
Jan 25 2012, 12:31 PM
Newbie ![]() Group: Members Posts: 44 Joined: 26-November 11 From: Arcata, CA Member No.: 13,822 Region Association: Northern California |
my recently purchased '75 5.7 is sagging in the rear, and I'm hoping someone can help me out. The clips are set to highest setting and it's still low, and when I jounce the rear end, there's no movement. here's my questions:
1. what do I have now, the coil diameter is roughly 3.625 (92 mm) X .47 (12 mm). 2. Renegade recommends 200# springs but only sells the coil over kit $350 or so. Where can I get springs for this shock? (IMG:style_emoticons/default/idea.gif) Any advice would be much appreciated. Thanks Attached image(s)
| Chris Pincetich |
Jan 25 2012, 11:47 PM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
more pics would help
Most 914s look low in back, that is normal V8s are heavy, so yeah, yours could be suffering, but it could be "something else" The coil-over conversion opens up a world of new options, which is why I pulled the trigger and got one. A set of springs is included in the cost (IMG:style_emoticons/default/beerchug.gif) I am using 175# springs, stock TIV, newish Koni yellow shocks, 205/50 tires, but have needle bearing suspension pivot bushings so the 175# is not "as stiff" as if used with bushings that experience more friction |
| xsJerry |
Jan 26 2012, 11:59 AM
more pics would help Most 914s look low in back, that is normal V8s are heavy, so yeah, yours could be suffering, but it could be "something else" The coil-over conversion opens up a world of new options, which is why I pulled the trigger and got one. A set of springs is included in the cost (IMG:style_emoticons/default/beerchug.gif) I am using 175# springs, stock TIV, newish Koni yellow shocks, 205/50 tires, but have needle bearing suspension pivot bushings so the 175# is not "as stiff" as if used with bushings that experience more friction here's some profile pics. I measured it at the donuts, and found about 3/8" lower in the rear (probably about 1/2" for the length of the car). It does give an impression of pointing upward as you are driving. Attached image(s)
| xsJerry |
Jan 26 2012, 12:03 PM
it's also about 1/4" lower on the right side rear than the left. you can kind of see this in the photos (looks lower in the rear when looking at the passenger side)
| Rand |
Jan 26 2012, 12:08 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
it's also about 1/4" lower on the right side rear than the left. you can kind of see this in the photos (looks lower in the rear when looking at the passenger side) Do some serious examination of the suspension console and ear on that side. I hope you don't find any serious rust or cracks. I like the looks of the rear height as you have it. I would lower the front and put some lower profile tires on - but that's partially a personal taste thing. Then readjust the alignment. Maybe corner balance. |
| SirAndy |
Jan 26 2012, 01:11 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
it's also about 1/4" lower on the right side rear than the left. you can kind of see this in the photos (looks lower in the rear when looking at the passenger side) Do some serious examination of the suspension console and ear on that side. I hope you don't find any serious rust or cracks. (IMG:style_emoticons/default/agree.gif) |
xsJerry bilstein shock questions Jan 25 2012, 12:31 PM
Andyrew Show some pictures of the "sagging" rear... Jan 25 2012, 12:47 PM
jmmotorsports Pelican Parts, Performance Products. AutoAtlanta, ... Jan 25 2012, 12:48 PM
xsJerry
Pelican Parts, Performance Products. AutoAtlanta,... Jan 25 2012, 02:12 PM
bulitt Automotion also carries 200lb springs. Jan 25 2012, 02:14 PM
jmmotorsports
180... Jan 25 2012, 02:53 PM
sean_v8_914 suspension is a system. Proper handling is a safet... Jan 25 2012, 10:48 PM
xsJerry
suspension is a system. Proper handling is a safe... Jan 25 2012, 11:45 PM
sean_v8_914 have those springs been cut?
I think stacking weig... Jan 25 2012, 10:51 PM
dlo914 If ya eventually don't like the bilsteins, how... Jan 26 2012, 01:29 AM
Eric_Shea :agree: lower the front. :D I like the tires tho... Jan 26 2012, 12:31 PM
Andyrew Those are some tall tires...
I agree with the bo... Jan 26 2012, 08:40 PM
ppetion
I agree with the b... Jan 27 2012, 12:25 AM
computers4kids
I agree with the ... Jan 27 2012, 09:18 AM
xsJerry Thanks all. I havn't seen any rust at all on t... Jan 27 2012, 01:06 PM
nsr-jamie Its easy to lower the front end. Also you may want... Jan 26 2012, 09:45 PM
sean_v8_914 rt rear is low and has more neg camber. everyone e... Jan 26 2012, 09:57 PM
Rand Lowering the front is super quick and easy by just... Jan 27 2012, 01:20 PM
KELTY360
Lowering the front is super quick and easy by jus... Jan 28 2012, 12:40 AM
Rand Here's a thread with bad suspension console ea... Jan 27 2012, 01:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 10:17 AM |
