| tornik550 |
Jan 27 2012, 10:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I recently finished rebuilding my engine and I am ready for the break in. Today, I went outside and quickly tried to start it for the first time. I only tried for a very short amount of time. I got a couple of backfires (with flames!) out the exhaust. It really sounded like a timing issue. It could be a carb issue but I figured I better get this straighten out first- so here is my question.
When rebuilding an 050 distributor- which way is the rotor supposed to point in relation to the drive flange? Does the dizzy in the picture have the correct flange orientation? ![]() |
| Valy |
Jan 28 2012, 12:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
As far as I know, that piece can only go one way.
but, the gear that it plugs into can jump teeth from correct alignment. |
tornik550 Distributor flange orientation question Jan 27 2012, 10:05 PM
Valy
As far as I know, that piece can only go one way.... Jan 28 2012, 01:00 AM
euro911 Yes, double check your distributor drive gear ... ... Jan 28 2012, 10:35 PM
pilothyer Your drive flange is in the correct position...it ... Jan 29 2012, 12:43 AM
Cap'n Krusty Why would you ever take apart an 050?
The Cap... Jan 29 2012, 01:26 AM
nathansnathan The 050 I've got is in the same orientation as... Jan 29 2012, 08:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th June 2026 - 03:53 AM |
