| tornik550 |
Jan 27 2012, 10:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I recently finished rebuilding my engine and I am ready for the break in. Today, I went outside and quickly tried to start it for the first time. I only tried for a very short amount of time. I got a couple of backfires (with flames!) out the exhaust. It really sounded like a timing issue. It could be a carb issue but I figured I better get this straighten out first- so here is my question.
When rebuilding an 050 distributor- which way is the rotor supposed to point in relation to the drive flange? Does the dizzy in the picture have the correct flange orientation? ![]() |
| pilothyer |
Jan 29 2012, 12:43 AM
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Your drive flange is in the correct position...it only goes on one way. When the #1 piston is at the top of it's compression stroke (NOT THE EXHAUST STROKE !!) the driveshaft for the distributor should be lined up in such a way that the slot is approx. 12 Degrees CCW from straight up and down when you look into the hole, and the large segment will be on the right....orient your distributor to fit that way and the rotor should be pointed at #1......This may be as clear as mud, but the best way I could put it............Jerry
tornik550 Distributor flange orientation question Jan 27 2012, 10:05 PM
Valy As far as I know, that piece can only go one way.
... Jan 28 2012, 12:50 AM
Valy
As far as I know, that piece can only go one way.... Jan 28 2012, 01:00 AM
euro911 Yes, double check your distributor drive gear ... ... Jan 28 2012, 10:35 PM
Cap'n Krusty Why would you ever take apart an 050?
The Cap... Jan 29 2012, 01:26 AM
nathansnathan The 050 I've got is in the same orientation as... Jan 29 2012, 08:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th June 2026 - 03:55 AM |
