| mikea100 |
Jan 9 2012, 08:28 PM
Member ![]() ![]() Group: Members Posts: 181 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
Yesterday, with some help from my 2 boys, I got my '76 2.0 short block on the engine run stand. I need help setting it up. It's late 2.0, complete, all stock, EFI. I'm looking for any info, any help at all. I've read few dozen threads about engine stands, but most of them deal with yokes, adapters and such. I need help with wiring and actually test running the engine. If local guys can stop by this long weekend and land me a hand, you'd really do me a solid and I'll return the favor. I'll serve beer of your choice. (IMG:style_emoticons/default/beerchug.gif)
Thanks, Mike Attached image(s)
| jonferns |
Jan 30 2012, 11:18 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States
Mike, I may have an MPS accessible in my mess of a garage. You can borrow it if you cant find yours. You can swing by and pick it up this week sometime if you'd like.
mikea100 Testing engine on run stand Jan 9 2012, 08:28 PM
Jeffs9146 It looks like you used nails or screws to hold tha... Jan 9 2012, 09:24 PM
mikea100
It looks like you used nails or screws to hold th... Jan 9 2012, 10:35 PM
RobW What are you testing? Jan 9 2012, 10:40 PM
mikea100
I just want to make sure t... Jan 10 2012, 05:56 PM
Jeffs9146 I have some engine run stand exhaust that you migh... Jan 10 2012, 06:22 PM
windforfun Too bad Thomas isn't around to help. Sorry, I... Jan 10 2012, 07:24 PM
Vacca Rabite Actually, as long as you have the engine like that... Jan 10 2012, 08:42 PM
mikea100
Actually, as long as you have the engine like tha... Jan 10 2012, 09:26 PM
Vacca Rabite I used the cheapest push button starter switch I c... Jan 10 2012, 10:49 PM
jcd914 Add to your engine stand a place to hang your FI c... Jan 11 2012, 02:49 AM
jcd914 The connector pin list I posted was inputs/outputs... Jan 18 2012, 05:48 PM
mikea100 First of, please be patient with me as I'm new... Jan 17 2012, 11:26 PM
dlee6204
Correct Jan 18 2012, 12:09 PM
Dave_Darling You'll need power to the coil.
You'll nee... Jan 18 2012, 12:28 PM
mikea100 I'm having trouble with this seemingly easy ta... Jan 22 2012, 06:28 PM
Dave_Darling The battery + should connect to the big post on th... Jan 22 2012, 07:14 PM
mikea100
The battery + should connect to the big post on t... Jan 23 2012, 10:54 AM
mikea100
The battery + should connect to the big post on t... Jan 24 2012, 02:02 PM
PRS914-6 Posted on this thread as well: Ready for break in-... Jan 22 2012, 09:04 PM
mikea100
Posted on this thread as well: Ready for break in... Jan 23 2012, 11:05 AM
ape914 just put it in the car, 914's are blessed with... Jan 23 2012, 12:54 PM
Dave_Darling The decimals should be the thickness of the conduc... Jan 24 2012, 03:57 PM
mikea100 I traced most of the 12 pin connections, but some ... Jan 26 2012, 11:30 PM
Dave_Darling The connections vary a little from year to year.
... Jan 27 2012, 04:48 PM
mikea100 Thanks Dave.
I finally got a compression gauge and... Jan 28 2012, 10:41 PM
Dave_Darling Intakes are the middle valves, exhausts are the ou... Jan 28 2012, 11:14 PM
mikea100 I did the valve adjustment today and remeasured. I... Jan 29 2012, 08:26 PM
Vacca Rabite
I did the valve adjustment today and remeasured. ... Jan 30 2012, 06:22 PM
mikea100
Mike, I may have an MPS accessible in my mess of ... Jan 30 2012, 12:30 PM
ruddyboys I am going to try this in a few weeks. 1st questio... Jan 30 2012, 04:09 PM
mikea100
I am going to try this in a few weeks. 1st questi... Jan 31 2012, 09:35 AM
nathansnathan Also you want to make sure all the spark plugs are... Jan 30 2012, 07:06 PM
mikea100 The engine was cold, I don't believe that it h... Jan 30 2012, 08:04 PM
ruddyboys The black purple goes to the tach, so I wont be ne... Jan 31 2012, 03:08 PM
Dave_Darling There is no purple wire on the coil that I am awar... Jan 31 2012, 05:26 PM
mikea100 I have great news to report. I did as Nathan sugge... Jan 31 2012, 09:21 PM
mikea100 I've had no luck in getting this engine runnin... Feb 24 2012, 10:33 PM
Al Meredith Whenever I build an engine I run it on my engine s... Feb 25 2012, 10:27 AM
Prospectfarms
Yesterday, with some help from my 2 boys, I got m... Feb 25 2012, 10:43 AM
Tom Did you hook up your relay board? That is needed t... Feb 25 2012, 10:57 AM
mikea100 Tom,
The relay board is hooked up, however, I have... Feb 25 2012, 07:08 PM
Tom It looks like you are not getting power to the ECU... Feb 26 2012, 07:46 AM
Prospectfarms
It looks like you are not getting power to the EC... Feb 26 2012, 09:37 AM
Tom Wow Stuart,
Those are great diagrams. Thanks ... Feb 26 2012, 10:09 AM
mikea100 Thank you guys, those diagrams are great. My alter... Feb 27 2012, 08:05 PM
Tom mikea100,
Pins 12 and 14 are the power to the ... Feb 27 2012, 08:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2025 - 08:11 PM |
