> garage lighting idea, CFL, incan,or 4 footers, 4 foot to cfl and comparrison of all 3 styles
Tom
post Jan 27 2012, 02:32 PM
So I have three 4-foot shop lights in my garage. When they all are working, the light is pretty good. However, the dern bulbs keep burning out!! I have had CFL's in my outside lights for several years and have yet to have to replace one. So, I thought, why not put CFL's in the garage? So here is what I did. I like it so far and only have two 100 watt CFL's in the fixture, with room to add two more.
Found a fixture at Goodwill for $3.99 and 4 CFL's for $1.49 for two, so a total of less than $8.00 invested and about 1 hour to modify.
First is the before pic and then the after, followed by a couple of the modification pics.
Tom
Prospectfarms
post Jan 31 2012, 10:06 AM
Tom,
Thanks for raising an interesting, "I didn't know I wanted to know but now I do," topic, this time concerning compact and tube florescent lighting. As another post mentioned, CFL's are small florescent lights. Their tubular florescent antecedent has existed since the 1930's (per DOE)
Tired of replacing 4' bulbs, you retrofitted a fixture ("troffer") to accept CFL's, leading to an interesting discussion of the relative merits of each.
Despite the older technology, 4' tubes are slightly more efficient when measured in raw lumens per watt of power consumed. The difference is negligible compared to incandescents. There's almost no difference in watts per lumen between T8 and T12.
DOE 4' Florescent Study
DOE CFL lumens per watt requirements
One finding of the first study is how much the size and shape of the troffer affects usable florescent light output.
I use both tubes and CFL's and find the CFL's put out brighter light over less area (no surprise). CFL's and screw-in fixtures are also easier to find and install and the bulbs are less fragile.
Tom, is that Goodwill 4 bulb fixture wired in series or parallel? Does it matter?
Tom   garage lighting idea, CFL, incan,or 4 footers   Jan 27 2012, 02:32 PM
Tom_T   Tom, You probably have bad ballasts in the 4...   Jan 27 2012, 02:48 PM
JawjaPorsche   You make me sick! Your garage is so organized...   Jan 27 2012, 02:48 PM
wingnut86   Great lighting. We should have another "how ...   Jan 27 2012, 03:05 PM
Valy   What is this? Do you perform brain surgery in ...   Jan 27 2012, 07:50 PM
bigkensteele   What is this? Do you perform brain surgery in...   Jan 27 2012, 07:56 PM
Jeffs9146   Great lighting. We should have another "how...   Jan 27 2012, 10:54 PM
Tom   Tom T., I have had those 4 footers for 10 yea...   Jan 27 2012, 04:24 PM
wingnut86   Never, It's just a figment of my imasculation...   Jan 27 2012, 04:36 PM
wingnut86   ...the key word should have been the hint "Fi...   Jan 27 2012, 10:40 PM
76-914   The newer style (is it T8) are much brighter than ...   Jan 28 2012, 09:04 AM
Tom   I thought of all new fixtures, but hey, I own a 91...   Jan 28 2012, 11:09 AM
osvolant   I agree with Tom T and others- electronic ballast ...   Jan 28 2012, 12:37 PM
underthetire   Ya, good fixtures will make bulbs last a long time...   Jan 28 2012, 01:40 PM
PanelBilly   Few years ago I put a HO 8' fixture in the sho...   Jan 28 2012, 01:51 PM
Vacca Rabite   I am also a convert to the T8 bulbs and electronic...   Jan 28 2012, 04:36 PM
Tom   Thanks for all of the replys. I will use these unt...   Jan 30 2012, 09:49 PM
Prospectfarms   Tom, Thanks for raising an interesting, "I d...   Jan 31 2012, 10:06 AM
Tom   Prospectfarms, Parallel. Yes, it matters. An...   Jan 31 2012, 10:19 AM
Tom   Three pics: #1 - One 100 watt incandescent la...   Jan 31 2012, 11:15 AM
Prospectfarms   Big difference favoring the "old fashioned...   Jan 31 2012, 03:48 PM
Tom   Edited first post to reflect comparrison of 4 foot...   Feb 1 2012, 02:12 PM
Al Meredith   Lamps are rated in lumens per watt. A lot like Mil...   Feb 1 2012, 05:14 PM
Tom   Al, Thanks for the math, it strengthens my dec...   Feb 1 2012, 07:25 PM
Al Meredith   Tom, The rule of thumb is that a CFL (compact fluo...   Feb 2 2012, 12:05 PM
- Lo-Fi Version Time is now: 9th June 2026 - 10:20 AM
