| jules2c |
Jan 24 2012, 08:39 PM
Newbie ![]() Group: Members Posts: 16 Joined: 15-January 12 From: Milton Keynes Member No.: 14,010 Region Association: None |
I do not know if anyone has done this before it just seemed a sensible idea at the time. The car had all the usual disasters and a few novel ones made by the factory! This may offend purists but it had been rearly abused and I could not believe the crazy design of just about everything. It was a 74 2.0 4, it has been stripped of most parts and I have been slowly welding it back to a solid structure.
The doors have very good alignment and operate as I assume they should but the roof will not align at the rear being flush on the right side and sticking out about 4 to 5mm on the left. I straightened the left long which was about 4 to 5mm high in the middle this seemed to make no difference. The fiberglass roof I assume is accurate as I have not come across fiberglass warping I just dont know. If you have any ideas please let me know. Has anyone mounted a rad in the back of the car using the engine deck as the outlet feeding from the floor? More metal abuse tomorrow and the the next etc etc. |
| rohar |
Feb 1 2012, 05:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
Mounting a VW inline 4 (diesel or gas) longitudinally in a 914 is a PITA. No place for motor mounts on the driver side of the "front" of the engine.
jules2c Bluesport Retro Jan 24 2012, 08:39 PM
rick 918-S
I do not know if anyone has done this before it j... Jan 24 2012, 11:04 PM
jules2c
I do not know if anyone has done this before it ... Jan 25 2012, 02:23 PM
jules2c Thanks for information, now to try again to upload... Jan 25 2012, 02:35 PM
ape914 i think a engien grill mounted radiator is a great... Jan 26 2012, 12:25 AM
dlo914
i think a engien grill mounted radiator is a grea... Jan 26 2012, 01:27 AM
jules2c Thanks for advice, I did not know it sucked from a... Jan 26 2012, 08:42 PM
jules2c Thanks for information, it always helps to not rei... Jan 26 2012, 08:53 AM
majkos Wow!
You're good !
You got some ski... Jan 26 2012, 05:41 PM
rohar If you mount a VW engine transverse with the stock... Jan 26 2012, 08:52 PM
jules2c Thanks for your thoughts, not sure about the VW tu... Jan 27 2012, 08:09 PM
geniusanthony I have no experience with that diesel, but have tw... Jan 27 2012, 07:55 PM
jcd914
I have no experience with that diesel, but have t... Jan 27 2012, 09:13 PM
rohar
[quote name='geniusanthony' post='1613122' date='... Jan 31 2012, 09:42 AM
geniusanthony That's good to know Jim. What is the engine co... Jan 28 2012, 08:46 AM
jules2c Have thought of tilting the next engine forward as... Jan 31 2012, 06:43 AM
Jon Fernandes Check out the TDIclub.com forums, there is a Conve... Jan 31 2012, 09:34 AM
jules2c That is correct, the use of the entire engine gear... Jan 31 2012, 02:06 PM
paroxysm How about a b5 tdi passat mounted longitudinal, or... Jan 31 2012, 06:29 PM
paroxysm
Mounting a VW inline 4 (diesel or gas) longitudin... Feb 1 2012, 07:39 PM
jules2c Just thought this might be of interest, in the pho... Feb 2 2012, 10:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 10:20 AM |
