| 914Gelb |
Feb 8 2012, 03:06 AM
Member ![]() ![]() Group: Members Posts: 107 Joined: 7-July 11 From: Vienna Member No.: 13,288 Region Association: Austria |
Hello guys,
I've bought my car without any test drive because it was unsed many years. Now my transmission is on my todo list. I already opened the case to inspect the 1st gear. I saw a syncro ring which seems to be less used but the dog teeth and the slider speeks other words. My impression.. I have to change slider, dog teeth and syncro. I added some pictures, who can distinguish between poo parts and reusable ones. Attached thumbnail(s) |
Dr Evil Your slider looks fantastic. The gears show typica... Feb 8 2012, 08:55 AM
Dr Evil Oh, while you are in there, you should change out ... Feb 8 2012, 08:56 AM
914Gelb
Oh, while you are in there, you should change out... Feb 9 2012, 01:50 AM
jimkelly no pic of a worn out slider but its the teeth, jus... Feb 9 2012, 04:01 AM
914Gelb I now know how new teeth should look like, but is ... Feb 9 2012, 04:57 AM
Dr Evil You can reuse teeth from other gears as long as yo... Feb 9 2012, 12:39 PM
Dr Evil As for wear limit, I do not know of an indicator. ... Feb 9 2012, 12:41 PM
914Gelb Hello
I continued my transmission rebuild and ha... May 14 2012, 11:49 PM
Dr Evil That is toast. The race in the case should not mov... May 15 2012, 06:50 AM
914Gelb So, it'S not possible to get ring and pinion i... May 15 2012, 07:04 AM
Richard Casto Georg,
Regarding the bore for the roller bearing,... May 15 2012, 02:17 PM
Dr Evil I agree that another core would be a better invest... May 15 2012, 02:55 PM
914Gelb Thanks for the answers! I also think it makes... May 15 2012, 11:35 PM
Dr Evil There is another alternative to changing cases. Th... May 16 2012, 06:38 AM
914Gelb I will measure the outer race of the bearing, do I... May 20 2012, 01:24 PM
Dr Evil Yes, the bearing should be replaced as a unit to b... May 20 2012, 02:46 PM
914Gelb Hello,
I measured the ring 72.00mm!
May 23 2012, 01:03 PM
914Gelb Next step of transmission rebuild, 1st gear dogtee... May 23 2012, 01:21 PM
914Gelb Next step installation of new dogteeht.
May 23 2012, 01:35 PM
914Gelb Last step the check according the manual. Perfect.... May 23 2012, 01:45 PM
Dr Evil Hey Georg,
Great work. I have had only one ring b... May 23 2012, 02:07 PM
Dr Evil Did you need the smaller bearing that goes above t... May 23 2012, 02:08 PM
As Mike mentioned above, sometimes the rin... May 23 2012, 02:56 PM
914Gelb I continued my work with cleaning some parts of th... May 27 2012, 01:50 PM
Dr Evil I will go out and measure the bearing right now. I... May 27 2012, 02:31 PM
914Gelb That's fine, If I have all parts I will finish... May 27 2012, 02:37 PM
914Gelb I have to leave for today, I will anwser your mail... May 27 2012, 02:41 PM
914Gelb more pictures from my transmission rebuild. I made... Sep 10 2012, 12:15 PM
914Gelb 2nd option of S&P setting.
Pls. tell me y... Sep 10 2012, 12:23 PM
914Gelb I bought the tool (VW 385)to measure the pinion de... Oct 11 2012, 12:53 AM
Cairo94507 That is a beautiful transaxle you have there. Con... Oct 11 2012, 06:51 AM
rjames wow. Nicely done! Oct 11 2012, 10:43 AM
Dr Evil Good job, Georg :thumbsup: What was the price for ... Oct 11 2012, 11:25 AM
914Gelb Hello,
the price was match more than 400. The too... Oct 11 2012, 11:13 PM
Cairo94507 ....oh no....he wants to see the Doc's tool...... Oct 12 2012, 06:43 AM
Dr Evil My tool is made out of an old differential and was... Oct 12 2012, 03:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 10:38 AM |
