OT: Working on my shop car, The wagon Porsche never built. . . |
aircooledtechguy |
Dec 23 2011, 07:20 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I've had a long term project going now to turn my '67 Squareback into my shop car. While I love driving my 914, it has limitations as a daily parts hauler. I love old styling with new technology and updates, so my goal is to turn my humble Square into the wagon that Porsche never made. I want it to drive and handle more like a Porsche than a VW wagon and it's got to be a true "Sleeper" (not a real problem; since it's a wagon). (IMG:style_emoticons/default/shades.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689630.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.2.jpg) This has been a 4-5 phase project. Phase-1 - Convert it to Porsche 914 2.0L motor. Make it physically adapted to the car and running MS2 w/ Ford EDIS ignition. Get it tuned to be a daily driver. DONE!! (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.3.jpg) Phase-2 - Make the motor look good and freshen it up with new P&Cs. The heads were freshened only about 2K miles before I got it, by me when it was in a clients 914 that he converted to Subie power. I noticed that once I had a few miles on it myself, it was using a bit of oil. So I upgraded to a new set of 96mm P&Cs. So now it's a 2056. I had my local powder coater do all the tins in black and the plenum and runners in grey for a stock look. I'm running T-4 H/Es with a modified bus header and a Summit Racing Flow Master clone muffler. So I had those ceramic coated in black so they are not attention grabbers from the back. This car is a sleeper (IMG:style_emoticons/default/happy11.gif) DONE!! Phase-3 - Convert the rear suspension to the later style IRS and install a Porsche 923 trans out of a Porsche 912E. The rear suspension is DONE!! While at it, I upgraded it with 914 rear brakes, urethane bushings, adjustable spring plates and a rear sway bar. (IMG:style_emoticons/default/driving.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689632.4.jpg) Since the trans is taller than a stock 4-speed and cutting into the car can't happen due to rear seat issues. I gained the 1.5" I needed by spacing the body off the rear suspension with spacers. So here I sit, on the final leg of phase-3. I now need to couple the motor/trans and lift it into it's final place and fab rear engine hanger mounts for the rear bar. It's late and I'm tired. . . Phase-4 - Front suspension upgrade. Currently in-work Phase-5 - Paint so it doesn't look so crappy, though it does add to the "sleeper" persona. . . Stay tuned for more later. . . |
aircooledtechguy |
Dec 24 2011, 08:36 PM
Thanks for the kind words guys. I've had this car for about 8 years in various set-ups but basically stock.
is it i window warper? do the side windows bend open instead of being hinged? No. Regular hinged type quarters on Squarebacks. The fastbacks had the windows that just bent. . . Freaky!! What type of heat exchangers are those? This is a 2.0L right? The H/Es are from a VW 411/412. They are a very basic H/E like our 914 ones. Until I had them ceramic coated, I had been running a set of heavy Bus H/Es. They worked fine but took a long time to heat up the aluminum jacket that is cast around the pipes. These should heat-up within a couple blocks and I save about 20# off the back of the car (this thing is a drift car in the wet (IMG:style_emoticons/default/driving.gif) ). The motor is a 2.0L out of a 914. I've just added a set of flat-top 96mm P&Cs to bump it up to a 2056cc. With the worn P&Cs it was a lot of fun to spank Honda fart-cars out on the hwy. It pulled really strong. Now with the added CR and size, I should surprise a lot more too. (IMG:style_emoticons/default/happy11.gif) The car only weighs about 1800# (well more with my big @$$). |
Prospectfarms |
Feb 14 2012, 08:37 AM
Member Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
...The H/Es are from a VW 411/412. They are a very basic H/E like our 914 ones. Until I had them ceramic coated, I had been running a set of heavy Bus H/Es. They worked fine but took a long time to heat up the aluminum jacket that is cast around the pipes. These should heat-up within a couple blocks and I save about 20# off the back of the car (this thing is a drift car in the wet (IMG:style_emoticons/default/driving.gif) ) Aircooledtechguy Very interesting thread with nice photo's, thanks. The BA/BN heaters work so well I wonder if you've considered bypassing the H/E, like a '73 type 181? The combo seems like overkill in everything except a bus. Maybe off the shelf header's are not available and/or you feel H/E's are needed as a heat shield for the exhaust. Thanks again for the write up. |
Lo-Fi Version | Time is now: 7th June 2024 - 11:17 AM |
