| nsr-jamie |
Feb 16 2012, 02:19 AM
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Well, got my tank out and I have one of the Tangerine Racing fuel lines in stainless (just one line as my car has carbs) and I can not seem to find the instructions or have just misplaced them. I bought the line from Chris about 2 years ago.I have done a search but can't seem to find any threads about others installing them.
Just wanted to ask how much work it is and how hard and if anybody has some tips to share or even add some pictures. I hope I can do this myself this weekend. Do I need to pull out the carpet in the center tunnel area? Thank you |
| ww914 |
Feb 16 2012, 12:33 PM
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
[/quote]
THANK YOU !!! Chris !!! Perfect timing !! I will start to install these on Saturday with some friends. The tank is out and we are doing the entire suspension as well...lots of rust in the tank but not for long...its being treated as I write this now. I was hoping I didn't have to remove the center tunnel carpeting as I just installed new ones from A and P and also glued them in which now looks to have been a big mistake (IMG:style_emoticons/default/sad.gif) I am afraid the carpet may get damaged if I try to remove it.... [/quote] Look at the photo I posted. There are two sets of tabs that you must bend back before you can get the old lines out. You should put little pieces of rubber fuel line back where those tabs are on the new ones. Bottom line, you need to remove the carpet to do this. Some say to put shrink wrap on the entire length of the new line in the tunnel. I don't think this is necessary, but you must protect the lines where the tabs are located as that is metal against metal. |
nsr-jamie Installing Tangerine Racing stainless fuel lines Feb 16 2012, 02:19 AM
vsg914 How hard its gonna be depends on your mechanical a... Feb 16 2012, 07:33 AM
type47 Really, very easy but I had the engine/trans and t... Feb 16 2012, 07:50 AM
JmuRiz
Really, very easy but I had the engine/trans and ... Feb 16 2012, 09:31 AM
rick 918-S The only diffeculty for me was getting them throug... Feb 16 2012, 07:54 AM
ppetion It was Easy for me with the tank out and engine o... Feb 16 2012, 08:18 AM
AZ914 Jamie,
There is a video on YouTube by the other gu... Feb 16 2012, 08:38 AM
Racer Chris Email with a copy of the instructions sent. :) Feb 16 2012, 08:42 AM
nsr-jamie
... Feb 16 2012, 10:25 AM
Jon Fernandes I took care of mine with the engine in, and the re... Feb 16 2012, 08:52 AM
ww914 You have to remove the fuel tank. I already had th... Feb 16 2012, 09:27 AM
pete000 I did not know about the tabs up in there holding ... Feb 16 2012, 01:18 PM
bigkensteele What the others said AND WD40 your grommets, espec... Feb 16 2012, 05:55 PM
nathansnathan
What the others said AND WD40 your grommets, espe... Feb 17 2012, 09:22 AM
John
What the others said AND WD40 your grommets, esp... Feb 17 2012, 09:21 PM
Jeff Bowlsby Glycerine from the pharmacy will lube the rubber t... Feb 18 2012, 10:13 AM
jmill
Is there something readily available to lubricate... Feb 18 2012, 11:31 AM
02loftsmoor liquid soap, or silicone lube
Is there somet... Feb 18 2012, 11:50 AM
nsr-jamie Good news !! The fuel line is already inst... Feb 18 2012, 11:58 AM
ww914 Good job! Now get out there and drive it. What... Feb 18 2012, 12:23 PM
mtndawg :bump: Feb 2 2018, 05:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:34 PM |
