| nsr-jamie |
Feb 16 2012, 02:19 AM
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Well, got my tank out and I have one of the Tangerine Racing fuel lines in stainless (just one line as my car has carbs) and I can not seem to find the instructions or have just misplaced them. I bought the line from Chris about 2 years ago.I have done a search but can't seem to find any threads about others installing them.
Just wanted to ask how much work it is and how hard and if anybody has some tips to share or even add some pictures. I hope I can do this myself this weekend. Do I need to pull out the carpet in the center tunnel area? Thank you |
| pete000 |
Feb 16 2012, 01:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I did not know about the tabs up in there holding the lines. I pulled out the plastic ones with out much resistance. I will now have to go back in and pull the shifter and see if I put in the stainless ones through that tab correctly and insulate them with rubber.
nsr-jamie Installing Tangerine Racing stainless fuel lines Feb 16 2012, 02:19 AM
vsg914 How hard its gonna be depends on your mechanical a... Feb 16 2012, 07:33 AM
type47 Really, very easy but I had the engine/trans and t... Feb 16 2012, 07:50 AM
JmuRiz
Really, very easy but I had the engine/trans and ... Feb 16 2012, 09:31 AM
rick 918-S The only diffeculty for me was getting them throug... Feb 16 2012, 07:54 AM
ppetion It was Easy for me with the tank out and engine o... Feb 16 2012, 08:18 AM
AZ914 Jamie,
There is a video on YouTube by the other gu... Feb 16 2012, 08:38 AM
Racer Chris Email with a copy of the instructions sent. :) Feb 16 2012, 08:42 AM
nsr-jamie
... Feb 16 2012, 10:25 AM
Jon Fernandes I took care of mine with the engine in, and the re... Feb 16 2012, 08:52 AM
ww914 You have to remove the fuel tank. I already had th... Feb 16 2012, 09:27 AM
ww914
THANK YOU !!! Chris !!! ... Feb 16 2012, 12:33 PM
bigkensteele What the others said AND WD40 your grommets, espec... Feb 16 2012, 05:55 PM
nathansnathan
What the others said AND WD40 your grommets, espe... Feb 17 2012, 09:22 AM
John
What the others said AND WD40 your grommets, esp... Feb 17 2012, 09:21 PM
Jeff Bowlsby Glycerine from the pharmacy will lube the rubber t... Feb 18 2012, 10:13 AM
jmill
Is there something readily available to lubricate... Feb 18 2012, 11:31 AM
02loftsmoor liquid soap, or silicone lube
Is there somet... Feb 18 2012, 11:50 AM
nsr-jamie Good news !! The fuel line is already inst... Feb 18 2012, 11:58 AM
ww914 Good job! Now get out there and drive it. What... Feb 18 2012, 12:23 PM
mtndawg :bump: Feb 2 2018, 05:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:32 PM |
