> Engine rebuild, The reassembly started !
Valy
post Sep 3 2011, 01:38 AM
I got a spare engine with my car. The engine looks nice but the PO drained the oil out and left the sump open. Then he wrapped it in plastic wrap and dropped the engine on the left head so it has a nice crack.
Got myself a new pair of heads that are rebuilt right now.
It's going to be a big L-Jet as I don't have the patience to deal with the old D-Jet (although I have all the parts for a D-Jet). I
I'm going to make it a 2056cc unless in change my mind and go crazy with a bigger crank (IMG:style_emoticons/default/idea.gif)
I started taking the engine apart and going to document as much as I can.
Not my first rebuild but is my first Type4 rebuild so wish me luck!
Today I got pistons 3 & 4 out.
#3 looks nice, not too much signs of wear. The ring gaps are about 1mm (trash)
#4 is also nice but the piston got a small bent while trying to remove the pin. That bent trapped the oil ring. Never mind, I'm going for bigger one anyway.
The cylinder registers are nice. In fact, the entire case is very nice and clean.
Anyone knows the meaning of the inscriptions on the cylinders and pistons?
Dave_Darling
post Feb 16 2012, 03:22 PM
914 Idiot
Must be German Precision. That's what (almost) everyone says about them.
--DD
Valy   Engine rebuild   Sep 3 2011, 01:38 AM
dlee6204   :popcorn:   Sep 3 2011, 06:29 AM
stewteral   :popcorn: dlee6204, WOW! That's the M...   Sep 9 2011, 12:20 PM
Valy   :popcorn: dlee6204, WOW! That's the ...   Sep 9 2011, 12:30 PM
r_towle   :popcorn: dlee6204, WOW! That's the ...   Sep 9 2011, 01:58 PM
Valy   More work today and more surprises. Took off cylin...   Sep 4 2011, 07:47 PM
Dave_Darling   Piston writing: 93.97 == diameter in mm. That...   Sep 4 2011, 07:54 PM
bcheney   Piston writing: 93.97 == diameter in mm. That...   Sep 4 2011, 09:20 PM
Valy   Piston writing: 93.97 == diameter in mm. That...   Sep 4 2011, 09:31 PM
bcheney   Well...I'm not an expert on component wear...b...   Sep 4 2011, 09:38 PM
Vacca Rabite   Assuming you are going to put a non stock cam in t...   Sep 5 2011, 07:19 AM
Jake Raby   Yep, retention wire wear.. But if you do this job...   Sep 5 2011, 08:44 AM
Valy   Oil pump doesn't want to come off. I took the ...   Sep 5 2011, 10:22 AM
McMark   Yup, use the tabs and pry it off. I'm sure so...   Sep 5 2011, 10:27 AM
Valy   Yup, use the tabs and pry it off. I'm sure s...   Sep 5 2011, 11:00 AM
Vacca Rabite   Yup, use the tabs and pry it off. I'm sure ...   Sep 5 2011, 01:42 PM
Cap'n Krusty   [quote name='Valy' post='1534789' date='Sep 5 201...   Sep 5 2011, 01:55 PM
Valy   Just to make thing clear: The engine is a 914 2.0...   Sep 5 2011, 03:19 PM
McMark   I don't see any comments about temperature se...   Sep 5 2011, 07:21 PM
Cap'n Krusty   I don't see any comments about temperature s...   Sep 11 2011, 09:06 AM
McMark   The temp sensor installation shown in the picture...   Oct 20 2011, 02:36 PM
Valy   The temp sensor installation shown in the pictur...   Oct 20 2011, 07:19 PM
r_towle   Pry it off, be careful. Its held in tight, and the...   Sep 5 2011, 11:08 AM
John Jentz   Loosen some of those case nuts that surround it. ...   Sep 5 2011, 01:08 PM
Jake Raby   Worst case pull two of the studs on one case half ...   Sep 5 2011, 01:43 PM
Valy   Oil pump is out :Qarl: It has some wear on the d...   Sep 5 2011, 04:22 PM
Jake Raby   The lowermost pic of the oil pump shows a failing ...   Sep 5 2011, 04:30 PM
Valy   The lowermost pic of the oil pump shows a failing...   Sep 5 2011, 05:15 PM
jcd914   The shaft in the pump should be flush with the...   Sep 5 2011, 07:14 PM
jsconst   [quote name='Jake Raby' post='1534917...   Sep 11 2011, 08:37 AM
Jake Raby   There ya have it... What I said earlier.. This hap...   Sep 5 2011, 06:20 PM
Valy   Put all my flat screwdrivers away so I won't b...   Sep 9 2011, 12:30 PM
stugray   Chances are you missed a bolt or two. The case re...   Sep 9 2011, 01:20 PM
Valy   Chances are you missed a bolt or two. The case r...   Sep 9 2011, 01:44 PM
bigkensteele   Chances are you missed a bolt or two. The case ...   Sep 9 2011, 02:01 PM
Valy   Where did you get that cool billet engine stand a...   Sep 9 2011, 06:21 PM
Matt Meyer   Splitting Case Halves Classic Thread shows bolt lo...   Sep 9 2011, 01:48 PM
Vacca Rabite   :agree: Pull the flywheel. There are things behin...   Sep 9 2011, 04:45 PM
Jake Raby   Buy my damn video!! I go over every nut an...   Sep 9 2011, 07:22 PM
Valy   Buy my damn video!! I go over every nut a...   Sep 9 2011, 07:50 PM
bigkensteele   Buy my damn video!! I go over every nut a...   Sep 9 2011, 07:54 PM
Jake Raby   Buy my damn video!! I go over every nut ...   Sep 9 2011, 07:57 PM
mrdkrantz   Wooden wedges and an old animal hid mallet(if you ...   Sep 9 2011, 10:30 PM
euro911   The last engine case we split had a ton of sealant...   Sep 10 2011, 12:15 PM
Valy   WARNING: Horror pictures bellow. Don't scroll ...   Sep 10 2011, 10:34 PM
Vacca Rabite   Looks like an engine that had a lot of miles on it...   Sep 11 2011, 07:23 AM
Valy   Crankshaft and Rod journals. Some pictures of the...   Sep 11 2011, 03:50 PM
Valy   Update: My machinist finally measured the case and...   Oct 14 2011, 01:40 PM
Valy   Update: My machinist finally measured the case an...   Oct 14 2011, 04:21 PM
SLITS   The marks in the big end of the rod are from machi...   Oct 14 2011, 01:46 PM
Valy   New stuff is starting to arrive!!! :Qa...   Oct 20 2011, 01:48 PM
vsg914   Is that the top left or the bottom left? :stir:   Oct 20 2011, 02:51 PM
Valy   Those are AA pistons. Measured the ring gaps in t...   Oct 20 2011, 07:42 PM
Valy   Cam is here :Qarl: Lift is 8.2mm (0.323") ...   Nov 11 2011, 01:41 PM
Marty Yeoman   What WebCam part number is your cam?   Nov 11 2011, 02:14 PM
Valy   What WebCam part number is your cam? It's a ...   Nov 11 2011, 02:45 PM
Marty Yeoman   What WebCam part number is your cam? It's a...   Nov 15 2011, 02:25 PM
Valy   [quote name='Valy' post='1570171' date='Nov 11 20...   Nov 15 2011, 03:44 PM
Scarlet75   So thats not a Raby Cam?   Nov 11 2011, 05:00 PM
Valy   So thats not a Raby Cam? Nope. I bought it from ...   Nov 11 2011, 05:16 PM
Valy   Strange but true, the bolts that hold the gear on ...   Nov 11 2011, 05:42 PM
McMark   Because the tool suppliers have cheaper prices for...   Nov 11 2011, 06:57 PM
Kansas 914   Because the tool suppliers have cheaper prices fo...   Nov 11 2011, 07:00 PM
jcd914   Because the tool suppliers have cheaper prices f...   Nov 11 2011, 07:24 PM
jimbot2000   [quote name='Kansas 914' post='1570296' date='Nov...   Feb 20 2012, 10:07 AM
worn   Because the tool suppliers have cheaper prices fo...   Apr 6 2012, 08:59 AM
Valy   Main bearings arrived this morning. Those are +0....   Nov 12 2011, 11:08 PM
pilothyer   Valy, where's the rest of the story?   Feb 15 2012, 10:43 PM
Valy   Valy, where's the rest of the story? The eng...   Feb 15 2012, 10:54 PM
Dave_Darling   Must be German Precision. That's what (almost...   Feb 16 2012, 03:22 PM
Valy   Wow, the world was down for such a long time exact...   May 15 2012, 11:43 AM
Valy   [u]Oil Pump After my oil pump saga described in t...   May 15 2012, 12:13 PM
Valy   Oil Galleys Plugs I had the main oil galleys plug...   May 15 2012, 12:50 PM
Valy   [u]Gaskets I had to make a thicker gasket for my ...   May 15 2012, 12:51 PM
Valy   Crankshaft I re-built the crankshaft assembly. T...   May 15 2012, 12:51 PM
euro911   Hey Val, is that AL pump cover plate a tad thicker...   May 15 2012, 12:58 PM
Valy   Hey Val, is that AL pump cover plate a tad thicke...   May 15 2012, 01:07 PM
Valy   Connecting Rods I had the connecting rods recondi...   May 15 2012, 02:10 PM
Valy   One very important remark regarding rod assembly t...   May 15 2012, 02:41 PM
Valy   [u]Camshaft I'm using a new camshaft. This is...   May 15 2012, 02:51 PM
Valy   [b]Oil Pressure Regulator I had a [url=http://www...   May 15 2012, 02:56 PM
Valy   Half Case Assembly Mounted the distributor gear w...   May 15 2012, 03:15 PM
396   Sub... keep it coming., Great write up   May 16 2012, 05:15 AM
Valy   Windage/Baffle Plate My core engine came without ...   May 17 2012, 03:38 PM
Valy   Closing the Case With the windage plate, cam bear...   May 17 2012, 03:49 PM
Valy   [u]Type 1 Oil Pump Installation I've been thr...   May 17 2012, 04:10 PM
Valy   Oil Temp Sensor I didn't like the oil temp se...   May 17 2012, 06:26 PM
Valy   Deck Height I set-up my dial meter to find TDC an...   May 18 2012, 02:44 AM
Valy   Thermostat Slow progress this weekend as I was b...   May 21 2012, 02:49 PM
Valy   Fixing Broken a Tin Screw Hole Some PO of this en...   May 21 2012, 11:49 PM
Dave_Darling   That looks like it's near where the M8 hole is...   May 22 2012, 12:11 AM
Valy   That looks like it's near where the M8 hole i...   May 22 2012, 01:29 AM
McMark   Nope. Dave's right... About later cases. Early...   May 22 2012, 08:08 AM
Valy   Nope. Dave's right... About later cases. Earl...   May 22 2012, 09:28 AM
McMark   The thermo-time switch was moved towards the flywh...   May 22 2012, 09:48 AM
McMark   Here's a picture of the TTS in place on a 912E...   May 22 2012, 09:54 AM
Valy   Maybe it's a bus thing. I just double checked ...   May 22 2012, 10:25 AM
euro911   I've got a '75 GC case here that has the M...   May 22 2012, 11:16 AM
Valy   I'm not planning to take the insert out. The L...   May 22 2012, 12:03 PM
McMark   If you're running L-Jet, are you leaving off t...   May 22 2012, 12:04 PM
- Lo-Fi Version Time is now: 1st May 2026 - 02:45 PM
