| 914dave |
Jan 7 2012, 05:35 PM
914 Addict ![]() ![]() ![]() Group: Members Posts: 740 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States
Now that my six conversions has progressed the point where the rust is out of the chassis and the 3.2 mated to the 915 are mounted in the car. I'm taking this winter to fabricate shift linkage from the Vellios 915 to the JWest shifter. After finishing the rebuild of the 915, I realized that the shift pattern would be reversed in the car. 5th/reverse would be towards the drivers side of the car. I didn't like this idea. So I'm building a riser for the shifter to reverse the direction fo the pattern. I wanted the linkage to be very crisp. I'm using industrial U joints and spherical bearings where I can. This is the first part of the project, the firewall bushing. I'll be using the stock rubber accordian boot in this setup for weather protection. the following pix are fo the bearing and the nylon housing used to mount it to the firewall. the first pic is the original 914 tunnel shift rod machined down to fit in the spherical bearing. The final pic show shows it mounted with 2 screws, I'll drill for the other 2 when I get the motor out of the way.
![]() ![]() ![]() ![]() Attached image(s)
| Dion |
Feb 16 2012, 08:43 PM
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region
914dave Vellios-JWest shift linkage progress thread Jan 7 2012, 05:35 PM
Steve What kind of shifter are you going to use? I have... Jan 7 2012, 06:12 PM
wingnut86 :popcorn: Jan 7 2012, 06:38 PM
Dr Evil :popcorn: Jan 7 2012, 06:44 PM
Steve :popcorn: FYI popcorn is good for you!! Jan 7 2012, 06:55 PM
bigkensteele Just curious - is it not possible to fabricate a c... Jan 7 2012, 07:27 PM
Bob L.
Just curious - is it not possible to fabricate a ... Jan 7 2012, 07:53 PM
bigkensteele
Pertinent?? Fancy word, Are you getting impertin... Jan 7 2012, 09:49 PM
914dave I'm using the 914 rennshift, I've used it ... Jan 7 2012, 07:52 PM
John
I'm using the 914 rennshift, I've used it... Jan 7 2012, 08:55 PM
dudley4
I'm using the 914 rennshift, I've used it... Jan 7 2012, 09:46 PM
GeorgeRud I also have a Vellios 916 conversion, and use a st... Jan 7 2012, 09:54 PM
914dave "I am wondering what kind of muffler you will... Jan 8 2012, 07:32 AM
Steve I also have a 914 Rennshift today on my 914 trans.... Jan 8 2012, 09:19 AM
914dave "I bought Martin Bott's 916 kit from Germ... Jan 8 2012, 10:50 AM
John
Glad to help! The parts you made were by f... Jan 8 2012, 03:03 PM
914dave OK guys. I know it's been a while. Went to som... Feb 12 2012, 07:29 PM
914dave Here's a pic with the shifter mounted in the c... Feb 12 2012, 07:52 PM
914dave Here's some pix of the shifter assembly from t... Feb 12 2012, 08:03 PM
Eric_Shea Holy cool-shit Batman. Amazing work Dave. Feb 12 2012, 08:08 PM
GeorgeRud Thanks for the pics, I didn't know Vellios had... Feb 12 2012, 08:49 PM
wingnut86 Did you keep detailed measurements, material lists... Feb 12 2012, 09:26 PM
914dave Thanks guys. I've got drawings if anyone woul... Feb 13 2012, 08:12 AM
914dave With the shifter base being above the carpet I had... Feb 16 2012, 08:04 PM
wingnut86 SEXY :drooley: Feb 16 2012, 09:05 PM
GeorgeRud Beautiful work! Feb 16 2012, 09:52 PM
racerbvd :shock1: WOW[:shock1: :shock1: Feb 17 2012, 03:39 PM
Steve Nice job, but I am curious why you need the early ... Feb 18 2012, 11:20 AM
914dave Nice job, but I am curious why you need the early ... Feb 18 2012, 05:09 PM
Steve
Nice job, but I am curious why you need the early... Feb 18 2012, 06:42 PM
914dave Steve,
I hear what you're saying about the co... Feb 19 2012, 09:38 AM
Steve I'm also looking forward to not having to ... Feb 19 2012, 11:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 07:41 PM |
