> Vellios-JWest shift linkage progress thread, Started fabbing Vellios/JWest shift linkage
914dave
post Jan 7 2012, 05:35 PM
914 Addict
Now that my six conversions has progressed the point where the rust is out of the chassis and the 3.2 mated to the 915 are mounted in the car. I'm taking this winter to fabricate shift linkage from the Vellios 915 to the JWest shifter. After finishing the rebuild of the 915, I realized that the shift pattern would be reversed in the car. 5th/reverse would be towards the drivers side of the car. I didn't like this idea. So I'm building a riser for the shifter to reverse the direction fo the pattern. I wanted the linkage to be very crisp. I'm using industrial U joints and spherical bearings where I can. This is the first part of the project, the firewall bushing. I'll be using the stock rubber accordian boot in this setup for weather protection. the following pix are fo the bearing and the nylon housing used to mount it to the firewall. the first pic is the original 914 tunnel shift rod machined down to fit in the spherical bearing. The final pic show shows it mounted with 2 screws, I'll drill for the other 2 when I get the motor out of the way.
914dave
post Feb 18 2012, 05:09 PM
914 Addict
Nice job, but I am curious why you need the early style ball and socket shifter. Can't you use the 914 sideshifter rennshift and just flip it?
Steve,
The reason for the ball and socket is to reverse the shift pattern. Using the original coupler would put 1st/2nd gear shift plane on the passenger side of the car. Adding the 2 1/2" riser almost duplicates the original throw below the ball in the stock Rennshift. It's about 1/4" shorter. This way the throw of the shifter remains close to the same and the direction is reversed. Without making the shifter too tall.
Dave
Steve
post Feb 18 2012, 06:42 PM
QUOTE(914dave @ Feb 18 2012, 04:09 PM) *
Steve,
Dave
Thanks for the help!! Jwest said they would sell me the parts to convert mine to the ball and socket versus buying a new one. PMS also sells just the shift rod for the ball and socket that works with there firewall bearing that I have installed. Hopefully I won't run into any other surprises. My 916 trans is getting built at Hergesheimers. I could of bought a used Boxster for the price of this trans conversion.
(IMG:style_emoticons/default/hissyfit.gif)
914dave   Vellios-JWest shift linkage progress thread   Jan 7 2012, 05:35 PM
Steve   What kind of shifter are you going to use? I have...   Jan 7 2012, 06:12 PM
wingnut86   :popcorn:   Jan 7 2012, 06:38 PM
Dr Evil   :popcorn:   Jan 7 2012, 06:44 PM
Steve   :popcorn: FYI popcorn is good for you!!   Jan 7 2012, 06:55 PM
bigkensteele   Just curious - is it not possible to fabricate a c...   Jan 7 2012, 07:27 PM
Bob L.   Just curious - is it not possible to fabricate a ...   Jan 7 2012, 07:53 PM
bigkensteele   Pertinent?? Fancy word, Are you getting impertin...   Jan 7 2012, 09:49 PM
914dave   I'm using the 914 rennshift, I've used it ...   Jan 7 2012, 07:52 PM
John   I'm using the 914 rennshift, I've used it...   Jan 7 2012, 08:55 PM
dudley4   I'm using the 914 rennshift, I've used it...   Jan 7 2012, 09:46 PM
GeorgeRud   I also have a Vellios 916 conversion, and use a st...   Jan 7 2012, 09:54 PM
914dave   "I am wondering what kind of muffler you will...   Jan 8 2012, 07:32 AM
Steve   I also have a 914 Rennshift today on my 914 trans....   Jan 8 2012, 09:19 AM
914dave   "I bought Martin Bott's 916 kit from Germ...   Jan 8 2012, 10:50 AM
John   Glad to help! The parts you made were by f...   Jan 8 2012, 03:03 PM
914dave   OK guys. I know it's been a while. Went to som...   Feb 12 2012, 07:29 PM
914dave   Here's a pic with the shifter mounted in the c...   Feb 12 2012, 07:52 PM
914dave   Here's some pix of the shifter assembly from t...   Feb 12 2012, 08:03 PM
Eric_Shea   Holy cool-shit Batman. Amazing work Dave.   Feb 12 2012, 08:08 PM
GeorgeRud   Thanks for the pics, I didn't know Vellios had...   Feb 12 2012, 08:49 PM
wingnut86   Did you keep detailed measurements, material lists...   Feb 12 2012, 09:26 PM
914dave   Thanks guys. I've got drawings if anyone woul...   Feb 13 2012, 08:12 AM
914dave   With the shifter base being above the carpet I had...   Feb 16 2012, 08:04 PM
Dion   Awesome work Dave, Awesome! Cheers,Dion :beer...   Feb 16 2012, 08:43 PM
wingnut86   SEXY :drooley:   Feb 16 2012, 09:05 PM
GeorgeRud   Beautiful work!   Feb 16 2012, 09:52 PM
racerbvd   :shock1: WOW[:shock1: :shock1:   Feb 17 2012, 03:39 PM
Steve   Nice job, but I am curious why you need the early ...   Feb 18 2012, 11:20 AM
914dave   Nice job, but I am curious why you need the early ...   Feb 18 2012, 05:09 PM
Steve   Nice job, but I am curious why you need the early...   Feb 18 2012, 06:42 PM
914dave   Steve, I hear what you're saying about the co...   Feb 19 2012, 09:38 AM
Steve   I'm also looking forward to not having to ...   Feb 19 2012, 11:50 AM
- Lo-Fi Version Time is now: 12th March 2026 - 07:43 PM
