> Poly bronze A arm bushing installation
Harpo
post Feb 18 2012, 11:54 AM
I'm in the process of installing my new poly-bronz bushings and the directions say that if the fit is too loose to use urethane adhesive caulk. While at the local hardware store I could only find polyurethane caulk. will this work?
Thanks
6freak
post Feb 18 2012, 05:15 PM
MR.C
Right brand ! wrong product ......use Loctite Retaining compound...dont recall the # ...but then again how loose is loose..im talk n .005 or less to make the compound work proper..there are some 2 part epoxy`s that will work for sloppy fits....JMO
MikeC (IMG:style_emoticons/default/smile.gif)
Harpo
post Feb 19 2012, 12:40 PM
That is all that Home Depot had available. I will check with Lowes. The directions called for 50 -100 lbs of force. On one of the bushings I can press it together by hand. Maybee I'm making this more complicated than necessary but I only want to do this once.
Thanks
David
- Lo-Fi Version Time is now: 3rd April 2026 - 06:17 PM
