TheReverend |
The Reverend Rob ![]() Group: Members Posts: 17 Joined: 18-December 11 Member No.: 13,910 Region Association: Northern California ![]() |
Hey,
Anyone give me some details on thoughts for tracking down an electrical short? I replaced the battery, but within 3 days of not using the car, its dead as a doornail. I discounted the power to the radio, glove-box light.. How should I test it? what are the specs I should see different on the volt meter ? thanks all The Reverend. |
jimbot2000 |
Newbie ![]() Group: Members Posts: 43 Joined: 4-February 12 From: Bedburg- Hau, Germany Member No.: 14,083 Region Association: Europe ![]() |
Do you own and know how to use a multimeter? If so, (or if not) get your hands on one.
- Now disconnect the negative battery lead. - Configure the multimeter to read amperage. - Make sure the key is off (if you turn it on you're probably going to blow the fuse in your meter. -Connect it in series between the negative battery cable and negative battery terminal. - You should now see a measurement in amps. Probably pretty small if it takes 3 days. - Start pulling fuses one at a time. Pulling one fuse is going to show a significant decrease. - As you pull each fuse think logically about the circuit being deactivated. If it's same circuit as the clock for example, that's always going to run and pull a very small amperage. However, if you pull the one for the brake lamps, and your amperage draw decreases significantly, there's a problem here. Brake lights should pull no current, if the switch is open. Once you find the circuit that was causing the big draw, you have narrowed down your search field. Now have a look at that circuit, for places that move. Door pass throughs, switches, etc. Keep watching your meter as you move things around. (With the fuse back in of course), watch to see that when you open the door, or move the harness around if it has an effect on you reading. Now you have the general physical location, dig in and find your short. Keep in mind, most meters have a 10 amp fuse in them. You need to be careful not to turn on the headlights, stereo or anything that will pull more than 10 AMPs. Good luck! |
Lo-Fi Version | Time is now: 3rd July 2025 - 01:58 AM |
