| Harpo |
Feb 18 2012, 11:54 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I'm in the process of installing my new poly-bronz bushings and the directions say that if the fit is too loose to use urethane adhesive caulk. While at the local hardware store I could only find polyurethane caulk. will this work?
Thanks |
| worn |
Feb 20 2012, 10:13 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,561 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I'm in the process of installing my new poly-bronz bushings and the directions say that if the fit is too loose to use urethane adhesive caulk. While at the local hardware store I could only find polyurethane caulk. will this work? Thanks I am having trouble getting this. If these are what I think they are, they are pretty pricey bronze bushings offered from a particular specialist as a set. I can see how there might be a fit issue with parts at your end since they have no control over that. But the machined bushings and retainers are made to their specs and should fit each other perfectly without any added goo. Maybe I have this wrong and the fit is between the existing 914 clamps and the parts? |
Harpo Poly bronze A arm bushing installation Feb 18 2012, 11:54 AM
Harpo
Thanks
David Feb 18 2012, 12:04 PM
6freak Right brand ! wrong product ......use Loctit... Feb 18 2012, 05:15 PM
Harpo That is all that Home Depot had available. I will... Feb 19 2012, 12:40 PM
6freak After sleeping on this ...you have nice new stuff ... Feb 19 2012, 01:37 PM
6freak
very good stuff ..read directions Feb 20 2012, 09:06 AM
6freak
also very good stuff ...my first choice Feb 20 2012, 09:08 AM
6freak
I'm in the process of installing my new poly... Feb 20 2012, 10:31 AM
worn
[quote name='worn' post='1629077' date='Feb 20 20... Feb 20 2012, 11:33 AM
jimkelly so instructions say "if fit is too loose... Feb 20 2012, 10:40 AM
zig-n-zag I found a PL Premium Polyurethane Construction Adh... Feb 20 2012, 12:23 PM
Harpo According to Chuck Moreland of Elephant Racing the... Feb 20 2012, 03:53 PM
6freak
According to Chuck Moreland of Elephant Racing th... Feb 21 2012, 08:45 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd April 2026 - 06:11 PM |
