> Poly bronze A arm bushing installation
Harpo
post Feb 18 2012, 11:54 AM
I'm in the process of installing my new poly-bronz bushings and the directions say that if the fit is too loose to use urethane adhesive caulk. While at the local hardware store I could only find polyurethane caulk. will this work?
Thanks
worn
post Feb 20 2012, 10:13 AM
QUOTE(Harpo @ Feb 18 2012, 09:54 AM) *
Thanks
I am having trouble getting this. If these are what I think they are, they are pretty pricey bronze bushings offered from a particular specialist as a set. I can see how there might be a fit issue with parts at your end since they have no control over that. But the machined bushings and retainers are made to their specs and should fit each other perfectly without any added goo. Maybe I have this wrong and the fit is between the existing 914 clamps and the parts?
6freak
post Feb 20 2012, 10:31 AM
MR.C
QUOTE(worn @ Feb 20 2012, 08:13 AM) *
Thanks
you dont want them to move after install....its glue basically ..hope that helps ....kinda surprized someone else didnt chime in with tips and ideas
MikeC (IMG:style_emoticons/default/smile.gif)
worn
post Feb 20 2012, 11:33 AM
QUOTE(6freak @ Feb 20 2012, 08:31 AM) *
Thanks
I sort of figured that out. I was wondering why if they wanted an interference fit they didn't machine an interference fit. I am guessing the answer is that at least some of the components are off the shelf, and they vary in dimensions. They just look too nice for that.
- Lo-Fi Version Time is now: 3rd April 2026 - 06:17 PM
