| Dr Evil |
Feb 25 2008, 05:53 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Here is the latest gearbox I am building for someone. It is an F-N-X-HBf box and I wanted to show how easy it is to lock out 1st in a 4 speed box. I have heard that there are people that charge a chunk of change to do the same thing....I think that is wrong as it is way easy. All you need is a rear gasket, tubing cutter and a section of 3/8" copper tubing (1/2" shown as I bought the wrong size).
Here is the FNXHBf stack (Ooo, purdy). Here is the shift rod end for 1st that needs the sleeve to lock it out. I removed 1st gear completely other than the gear on the input shaft as you need it for reverse. ![]() And here is the section of ~2" copper tubing. You need to keep the slider for revers. It looks like the sleeve will hit the slider, but it is just the angle of the pic. |
| slothness |
Feb 27 2012, 03:22 PM
It's business time ![]() ![]() Group: Members Posts: 110 Joined: 7-October 04 From: Valencia, CA Member No.: 2,906 Region Association: Southern California |
(IMG:style_emoticons/default/smilie_pokal.gif) WANT
Dr Evil 4 speed tranny stuff for the V8 and high HP /6 crowd Feb 25 2008, 05:53 PM
Dr Evil This could easily be done by anyone with limited e... Feb 25 2008, 05:54 PM
So.Cal.914 Cool Evil... :) Feb 25 2008, 06:00 PM
dwillouby I did the same thing to mine. Also installed an H ... Feb 25 2008, 06:11 PM
Trevorg7 Is that the one we did at my place last month or a... Feb 25 2008, 06:12 PM
Dr Evil Nope, this is a different box. Feb 25 2008, 06:23 PM
BIGKAT_83
I did the same thing to mine. Also installed an H... Feb 25 2008, 06:30 PM
Dr Evil I was referring to the lockout modification as bei... Feb 25 2008, 06:43 PM
Dr Evil When you guys say that you flipped other gears, wh... Feb 25 2008, 06:44 PM
marks914 When Brad Mayeur did mine, he said it was no big d... Feb 25 2008, 07:35 PM
Dr Evil That seems like a tight grouping in the upper gear... Feb 25 2008, 08:09 PM
Dr Evil
That seems like a tight grouping in the upper gea... Feb 26 2008, 08:47 AM
michaelt55 Looks good to me Mike....
thanks..
Michael
... Feb 26 2008, 09:04 AM
rick 918-S What tire size are you using in your charts? 245/5... Feb 25 2008, 09:22 PM
Dr Evil Tire diameter of 25" Feb 25 2008, 09:29 PM
Andyrew So based on this info, with a 26" tire, and a... Feb 26 2008, 12:37 AM
Dr Evil
So based on this info, with a 26" tire, and ... Feb 26 2008, 08:24 AM
Andyrew
So based on this info, with a 26" tire, and... Feb 26 2008, 07:53 PM
Dr. Roger I think mine is a (1st gear delete) tight 1st, sec... Feb 26 2008, 02:38 AM
Dr Evil
I think mine is a (1st gear delete) tight 1st, se... Feb 26 2008, 08:23 AM
slothness Hey Doc, are you still rebuilding 1st gear lock ou... Feb 27 2012, 02:52 PM
type47fan . . . use one of these from a '65-'66 911/... Feb 27 2012, 03:21 PM
jimkelly who has best price on this knob???
found this...
... Sep 25 2015, 01:10 PM
Dr Evil Never an issue. Toss 1st gear, keep the race as a ... Feb 27 2012, 03:42 PM
matthepcat For those of us running a locked out first gear an... Feb 27 2012, 03:48 PM
Dr Evil Very easy. No special nothing needed. Feb 27 2012, 03:57 PM
slothness Thats what I hoped, I'll give it a try. Thanks... Feb 27 2012, 05:36 PM
Dr Evil Thanks for the endorsement, Mark :) Feb 27 2012, 09:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 04:26 AM |
