> another v8 conversion
kd0kqq
post Feb 27 2012, 03:04 PM
I need a little bit of of info on my v8 conv.
first off I all ready had the radiator and the engine. the engine is a fairly mild 283 maybe putting out 270hp on the high side.
I have a brand new stock 2.0 clutch and pressure plate my question is will that work on the modified flywheel no reason for a real stout clutch if it will just bake the tranny
i'v also seen where some people are using what looks to be like the stock water pump on the front of the engine how do they make that work.
Andyrew
post Feb 27 2012, 04:35 PM
Spooling.... Please wait
Electric pump really is the way to go. Summit Racing. One less belt, One less point of failure. Easy side of the road replacement, Decent cost.
Havent heard anything bad about the Rod Simpson mount. Is that the mound that attaches to the stock engine bar? Personally I would just do a welded tubular bar... I wouldnt touch a bolted together bar like that..
Clutch. Call up KEP (Kennedy Engineering) and tell them what your doing, they will get you a clutch package that'll work well for you. Your tranny will be fine with 270hp on a 283. Just dont use first (You wont need to), and dont drop the clutch in 2nd. You can still spin the tires and have fun, just be gentle.
kd0kqq   another v8 conversion   Feb 27 2012, 03:04 PM
slothness   Can really comment on the clutch since I'm run...   Feb 27 2012, 03:15 PM
pt_700   i have a rod simpson kit that uses a side mounted ...   Feb 27 2012, 03:22 PM
kd0kqq   ya it sounds like i'm going to have to go with...   Feb 27 2012, 03:26 PM
SirAndy   the engine is a fairly mild 283 maybe putting out...   Feb 27 2012, 04:00 PM
bulitt   Look for a meziere electric water pump on CL or Eb...   Feb 27 2012, 04:07 PM
Andyrew   Electric pump really is the way to go. Summit Rac...   Feb 27 2012, 04:35 PM
kd0kqq   will a stock mount eletric water pump fit where it...   Feb 27 2012, 05:58 PM
JRust   will a stock mount eletric water pump fit where i...   Feb 27 2012, 07:50 PM
914.SBC   Here is a pictue of the remote mount water pump th...   Feb 27 2012, 09:23 PM
kd0kqq   Thanks for all the info guys I think by the time I...   Feb 28 2012, 04:47 PM
914GT   My Dedenbear WP3 remote electric pump with WH1 wat...   Feb 28 2012, 06:18 PM
bulitt   My Dedenbear WP3 remote electric pump with WH1 wa...   Feb 29 2012, 06:57 AM
914GT   I'm using a modified ETK1 expansion tank, the ...   Feb 29 2012, 10:50 AM
kd0kqq   i love seeing pictures can any one get me a pic ...   Mar 1 2012, 12:45 AM
Andyrew   Between block and firewall, 2-3 inches max.   Mar 1 2012, 08:26 AM
kd0kqq   here is an update on my project I've got most...   Mar 29 2012, 11:34 AM
kg6dxn   Don't use 1st gear. Ever! Do not romp on t...   Mar 29 2012, 08:08 PM
kd0kqq   thanks for the advice i would like it to last for ...   Mar 30 2012, 10:27 PM
matthepcat   Welcome to the club! Maybe I should get an el...   Mar 30 2012, 11:30 PM
- Lo-Fi Version Time is now: 1st August 2025 - 12:32 PM
