Pertronix 'Ignitor' Module Question, How does one test it's functionality? |
euro911 |
Feb 25 2012, 02:20 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I just purchased a new 1844 'Ignitor' module. I read the instructions and installed it in the distributor.
I attempted to test the module with a Fluke VOM to verify it provides a pulse. I get a continuous reading of .2387 meg-ohms and the value does not change when the shaft is rotated by hand (yes, magnetic trigger ring is completely seated on the cam shaft). Does the module require 12vDC to see a pulse? ... or is it possible that this module is defective out of the box? (IMG:style_emoticons/default/confused24.gif) |
Tom |
Feb 27 2012, 07:21 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Mark,
Check step #5 in the link above under negative ground testing. As the magnetic sleeve is rotated around the pick up, the voltage will vary from 12 to 0 volts. Tom |
Lo-Fi Version | Time is now: 16th June 2024 - 02:49 AM |
