fuel pump problem, pulses with emergency lights |
Jesse |
Mar 4 2012, 03:53 PM
Jesse Group: Members Posts: 149 Joined: 15-February 10 From: Mobile, AL, USA Member No.: 11,363 Region Association: South East States |
so it took me a while to figure out that the pump would even work with the flashers on but anyways...
I have carbs so the pump is hooked up with SirAndys How to. When i turn on the key the pump kicks on for like a second then nothing, but if i turn on the hazard lights the pump comes on as the lights blink as in bump bump bump... i have traced wires and found no bad spots and nothing grounding out. any suggestions or help is welcome |
Valy |
Mar 4 2012, 10:26 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
so it took me a while to figure out that the pump would even work with the flashers on but anyways... I have carbs so the pump is hooked up with SirAndys How to. When i turn on the key the pump kicks on for like a second then nothing, but if i turn on the hazard lights the pump comes on as the lights blink as in bump bump bump... i have traced wires and found no bad spots and nothing grounding out. any suggestions or help is welcome Trace again. |
Lo-Fi Version | Time is now: 8th June 2024 - 07:15 PM |
