What's that sound?, Newbie requiring your expertise |
Germancar-Junkie |
Mar 5 2012, 08:04 AM
Man pedals aren't just for men Group: Members Posts: 51 Joined: 14-January 12 From: Weekdays, MD - Weekends, WV Member No.: 14,004 Region Association: MidAtlantic Region |
I finally got my most recent purchase up on the "big jackstand" and checked out the structural bits. There is some damage. Like it ran over a median or 10 ton bouder, but I can fix that.
The damage to the underside included tweaking the engine tins (both horizontal and vertical) about an inch up and an inch left on the driver's side. So the engine may have / must have taken a hit too. My biggest concern is the "clacking" sound the engine makes. I started it up just fine. It idled fine for the 20 seconds I was willing to let it run with all that racket going on. Then I shut it off and started running through the possibilities. Needless to say, most of them are not good. Gerbil with a jackhammer was the first one to come to mind. Just kidding. My question is, where should I start to try to find the source of this sound? Thanks, Dawn |
TheCabinetmaker |
Mar 5 2012, 10:15 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
First, and no offense to the chevy guys (I drive and repair chevy's too), but the sounds in a type 4 engine bay are nothing like that of a chevy. Check the fan like the others have said. If this is an unknown car, pull the covers and check the valves for one that is very loose. Since the engine sustained a hit, I would also check the heat exchanger and all its parts for tightness and fit, and the headers themselves for proper torque. A small leak there can sound like a very big clack. You didn't say how loud the clack is. That could be another clue. If you just can't find it, put it on jackstands and crawl under it with the engine running. Use a length of rubber tubing as a stethoscope to narrow it down.
Lo-Fi Version | Time is now: 11th June 2024 - 11:55 AM |
