| Tom |
Mar 9 2012, 12:30 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Have you checked yours lately? These seem to be becoming more of a problem. When I redid mine, I found the wires to have multiple broken strands at the solder to wire connection. As more strands are broken, the current carrying capacity of the wire is degraded. Below is something I copied from a forum on solder/crimp connections.
Almost any soldered joint will last forever if there's no vibration - that's the key. The solder itself isn't what fails, it's the interface point between the copper wire and solder, that's where the wires - not the solder - fail. How true and this is just what I found on mine. If yours are OK, a way to help prevent the breakage of the strands is to immobilize the 4 wire harness with a sticky pad and a nylon tie as close to the connection as possible. Two, one above the other would be even better. This would keep vibration and movement to a minimum. I think most of our cars used to have a small piece of thin sheet metal welded to the left rear side of the battery tray just for this purpose, however, most are long gone. From the pics of engine bays I have looked at, almost none were being used and the harness was hanging loose, allowing vibration and movement that stresses the soldered connection. If your 4 wire harness is long enough, you could do what I did in the pic attached. If you decide to do this, check how much movement you get by shaking the harness below the tie point and see how much less movement you get at the soldered connection. Tom Attached thumbnail(s) |
| 76-914 |
Mar 9 2012, 01:56 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,964 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Along those lines; years ago when I built my plane I was lucky enough to be around a couple of EE's that pointed out to me the importance of crimping the plastic sheathing around the crimp connectors. Look on your crimping tool and you will notice that one is marked "ins". This is the one to use on the plastic. It gives additional support to the wire/crimp/solder junction.
Tom Power wires at battery + Mar 9 2012, 12:30 PM
vsg914 Yep. The non insulated crimp spot on the tool will... Mar 9 2012, 03:50 PM
Tom The type of crimpers that 76-914 is talking about ... Mar 9 2012, 05:17 PM
Tom Over the last month, I have read several threads w... Sep 30 2012, 03:20 PM
damesandhotrods A crimp terminal gets two crimps. The first is fo... Sep 30 2012, 03:29 PM
Tom All terminal crimps do not get two crimps. A lot o... Sep 30 2012, 05:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 02:10 PM |
