V8 Grief, Now what do I do? |
Howard |
May 17 2004, 03:55 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Bottom line. Seller listed it as a '383 Chev with less than 300 miles on rebuild'. Also was supposed to have 'tall geared transmission'. Neither.
Thing was running incredibly rich and using 1 qt per 100 miles. Compression all over the map. Tried the obvious things, but gave up and took to a pro who tore it down. It's a 305 that's .030 over (310ci??). Looks like a fairly fresh rebuild with good parts, but wrong valve springs, so cam went flat. Lots of metal in oil, needs new cam, springs, rings (never seated and cylinders glazed), bearings, oil pump, valve job, and several yada yadas. Seller is a licensed CA auto dealer, I have copy of ad showing 383 and transmission mod's, so am confident he will get stuck with at least part of the bill if I go to court. But for now: My wrench says he can put it back together just fine , but advises I go to a crate 350 for about $1200 more. 383 is out due to 901 transmission. It would be nice to try to stick PO for a fresh 383 ($2500) tall geared tranny ($3000) and ~ $2000 for installation, but don't really want to go that far. 305, 350, or the works?? Attached image(s) |
Levi |
May 17 2004, 06:27 PM
Lick my nuts Group: Benefactors Posts: 623 Joined: 11-March 04 Member No.: 1,783 |
QUOTE(skline @ May 17 2004, 04:06 PM) QUOTE(Levi @ May 17 2004, 03:59 PM) WOW you guys are good, I've never meet anyone before now that could tell what kinda of SBC heads they were looking at, from the bottom of a bad picture, jeese I can't even tell without looking up the numbers.... (IMG:style_emoticons/default/lol2.gif) :lol2: :worship: The chamber size and the casting marks on the runners are the giveaway on the 305 heads. You are just used to 283's and 327's and 350's from your stable. Like I said your the best I've met... (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/lol2.gif) The engine in the 64 impala that I was posting pictures of is a 305, I've done em all, been doing Chevys, Big Blocks and Small blocks for about 25 years. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 11:40 AM |
