Loose Heads |
Loose Heads |
sweathappens |
Mar 15 2012, 03:55 PM
Newbie Group: Members Posts: 22 Joined: 25-February 06 From: Prunedale Member No.: 5,636 |
Re: My 1974 2.0 914.
I have had this car since about 1990. a couple of years ago I needed to rebuild the engine. I bought a rebuilt motor and the heads came loose. I took it to a local mechanic to re torque the heads. He could only get to the bottom four bolts on each cylinder as I expected. He said they torqued but one of the studs felt funny and suggested I rebuild the motor. I let him do the rebuild and he said the heads felt fine now. They came loose again. He says he didn't use head gaskets as they were not needed. I want to get this thing running right again. Why are my heads coming loose? Do I need gaskets on this motor. Some mechanics I have talked to say I need head gaskets and others say no. It would be interesting and helpful for you guys to chime in on this subject. |
brant |
Mar 15 2012, 04:11 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
my mechanic recommended a retorque of ALL of the head bolts after x number of miles of break in.
a couple of times in fact - you can pull all of the tin and access the head bolts for retorque -or you can drill the tin work (and use plugs to seal the air) so that access is possible without pulling the motor. |
MartyYeoman |
Mar 16 2012, 11:41 AM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
-or you can drill the tin work (and use plugs to seal the air) so that access is possible. I like that idea! (IMG:style_emoticons/default/agree.gif) I think I'll mod my tin to achieve this on the 2056 I'm building. |
rwilner |
Mar 16 2012, 01:13 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
did the factory use head gaskets?
Lo-Fi Version | Time is now: 16th June 2024 - 05:55 AM |
