> Towing with Tacoma
wndsnd
post Feb 14 2012, 08:00 AM
You wanted a horse, but got a goat. Nobody wants a goat....
I am planing on trying to tow a 914 with my 2010 Tacome 4cyl without towing package. It has a Curtis frame mounted hitch with a 2" ball. I was going to rent a uhaul full auto trailer. I don't want to be pushing the envelope. It will be mostly highway driving. Thanks
billh1963
post Feb 14 2012, 12:48 PM
Car Hoarder!
Even with a flat terrain you will be pushing it. I just brought back a 914 parts car on a uhaul trailer from Northern Alabama (close to Chattanooga)...the first 20 miles coming home had a series of steep hills and switchbacks....glad I had my 2006 turbodiesel F-250. I don't think a lesser truck would have made it. The uhaul trailer itself will be a load on a 4 cylinder.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i268.photobucket.com-12871-1329245284.1.jpg)
Randal
post Feb 14 2012, 04:42 PM
QUOTE(billh1963 @ Feb 14 2012, 10:48 AM) *
F250 Turbo's work great anywhere, you hardly even know there is a trailer back there.
Only negative is the cost of fuel and that is only going to bet worse.
billh1963
post Feb 14 2012, 07:11 PM
Car Hoarder!
QUOTE(Randal @ Feb 14 2012, 05:42 PM) *
Fuel will get worse, for sure. The good thing is I averaged 18 mpg towing the car back home. No gas powered truck will do that! (IMG:style_emoticons/default/aktion035.gif)
grantsfo
post Mar 14 2012, 01:37 PM
Arrrrhhhh!
QUOTE(billh1963 @ Feb 14 2012, 05:11 PM) *
I hear this a lot from diesel owners however I always make 17 to 18 MPG with my smaller displacement gas v8 Chevy and Fords towing on the highway if I keep it at 65 MPH and see upwards of 21 MPG not towing. My little 4.6 liter F150 work truck was mpg champ! My 4.8 Chevy gets pretty darn good mileage for being a crewcab. It takes a trained foot however and need to know how to use momentum to your favor. Part of this is due to lighter weight nature of the chevy and ford work trucks I buy. They dont have many extras run on little skinny tires, sit much lower than HD versions with diesels, etc. Hualling a little sub 4500 lb trailer and car doesnt impact mileage that badly. I always laugh when some guy in huge heavy duty 4x4 diesel pulls up and thinks he is getting better mileage than my little lightweight 2wd small displacement V8 truck.
Im sure if I was hauling a big enclosed unit my mileage would suck! But for lightweight stuff my little V8 is very comptitive mileage wise. And I can use regular gas!
This post has been edited by grantsfo: Mar 14 2012, 01:40 PM
billh1963
post Mar 22 2012, 02:48 PM
Car Hoarder!
QUOTE(grantsfo @ Mar 14 2012, 03:37 PM) *
Nice thought...until I get 18 mpg while towing through the mountains...and pass you and everyone else going up hill!.....which I have done on multiple occasions.
For day to day driving a small engine is great. However, for towing there is no substitute for the torque of a diesel. Also, don't forget that when towing a load my F-250 will outbrake an F-150 all day long. That makes a big difference for my towing comfort.
grantsfo
post Mar 22 2012, 11:05 PM
Arrrrhhhh!
QUOTE(billh1963 @ Mar 22 2012, 12:48 PM) *
Honestly I haven't found a mountain that slowed me much when hauling sub 5000 lb load in the newer Silverado? I did 70 mph all the way over the grapevine. Passed plenty of others too. Brakes on the Silverado are awesome no lack of stopping power. The older F150 wasn't best for brakes but newer Chevy had no issue hauling trailed down to a stop quickly.
Again if you're towing big enclosed rig big diesel is the way to go but smaller v8 gasser can be very efficient when towing lighter loads. You'd also be hard pressed to beat cost difference of a diesel verses cheap v8 gasser too. I bought my Crewcab with V8 and tow package new for $19k! most are flex fuel e85 burners now too which makes fuel costs even less than diesel.
Big old heavy duty diesel to hual a lightweight 914 on open trailer is a bit of overkill in my opinion. Most of new modern V8s make excellent HP and torque and are even more fuel effcient now. They have awesome brakes too.
I have just took step down to a much less capable 2012 v6 jeep Grand Cherokee. 290 hp 260 ft lbs. I getting 24.5 mpg hwy on my commute over mountain roads. It burns e85 too which I get for 35 cents a gallon less than regular. I will be towing 4500 lbs which is less than ideal but I needed a true dual use vehicle that got decent gas mileage and was nice to drive. It will be interesting to see how it works. Most of my towing is flat to local ax venue. Only a couple longer trips. My long term plan is to lighten my load by moving to a 2000 lb race car and aluminum trailer.
This post has been edited by grantsfo: Mar 22 2012, 11:57 PM
wndsnd   Towing with Tacoma   Feb 14 2012, 08:00 AM
6freak   I am planing on trying to tow a 914 with my 2010 ...   Feb 14 2012, 08:14 AM
mepstein   Probably no problem on level ground. It's hill...   Feb 14 2012, 08:21 AM
Joe Ricard   Suggest you borrow a friends truck. You do not ha...   Feb 14 2012, 09:03 AM
J P Stein   I wouldn't hesitate to tow a 914 behind my 200...   Feb 14 2012, 09:22 AM
bulitt   I believe any Uhaul dealer performing due-diligenc...   Feb 14 2012, 09:47 AM
underthetire   Shoot, we used to tow a 3500# sea ray behind my fr...   Feb 14 2012, 10:30 AM
ConeDodger   I have done heavier. You really can't push the...   Feb 14 2012, 10:51 AM
Randal   I have done heavier. You really can't push th...   Feb 14 2012, 12:23 PM
billh1963   Even with a flat terrain you will be pushing it. I...   Feb 14 2012, 12:48 PM
Randal   Even with a flat terrain you will be pushing it. ...   Feb 14 2012, 04:42 PM
billh1963   F250 Turbo's work great anywhere, you ha...   Feb 14 2012, 07:11 PM
grantsfo   Fuel will get worse, for sure. The good thing is ...   Mar 14 2012, 01:37 PM
billh1963   Fuel will get worse, for sure. The good thing is...   Mar 22 2012, 02:48 PM
grantsfo   [quote name='grantsfo' post='1645772' date='Mar 1...   Mar 22 2012, 11:05 PM
wndsnd   Well Thank you all for the great input. The car i...   Feb 14 2012, 05:33 PM
mepstein   I hope the car was a freebie. I wouldn't pay a...   Feb 14 2012, 05:57 PM
wndsnd   Unfortunately not a freebee - With flatbed I will ...   Feb 14 2012, 06:06 PM
billh1963   Ouch.....sounds like some of my mistakes   Feb 14 2012, 07:08 PM
jmill   I own a V6, 4wd, 4 dr. Tacoma and have done it. O...   Feb 14 2012, 07:15 PM
wndsnd   Well the mouse was cute.....   Feb 14 2012, 07:17 PM
stewteral   I am planing on trying to tow a 914 with my 2010 ...   Feb 14 2012, 07:18 PM
Randal   I am planing on trying to tow a 914 with my 2010...   Feb 14 2012, 08:57 PM
WolfR32   I am planing on trying to tow a 914 with my 2010...   Feb 27 2012, 02:04 AM
Zeke   Did you mean flat drag it? :blink: :poke:   Feb 14 2012, 08:37 PM
jcambo7   I pulled my 914 on a tow dolley from Oklahoma City...   Feb 14 2012, 10:10 PM
campbellcj   About 20 years ago I flat-towed a small car (VW Je...   Feb 17 2012, 09:55 PM
Eddie914   A lightweight car trailer would solve the problem....   Feb 19 2012, 11:50 AM
Eddie914   Before I acquired my Teener, I was at a local trac...   Feb 19 2012, 12:30 PM
rdauenhauer   Hey wndsnd I have the simple solution for you: Fl...   Feb 19 2012, 01:00 PM
dlee1967   I am still offering the tow bar interface brackets...   Feb 28 2012, 02:02 PM
euro911   Will the 'RennMetal and Bug tow bar' arran...   Feb 27 2012, 11:35 PM
WolfR32   Will the '[i]RennMetal and Bug tow bar' a...   Feb 29 2012, 02:07 AM
euro911   Will the '[i]RennMetal and Bug tow bar' ar...   Feb 29 2012, 09:15 PM
balljoint   I have towed my 914 with both a U-Haul auto-transp...   Feb 29 2012, 03:29 PM
andys   I have towed my 914 with both a U-Haul auto-trans...   Mar 1 2012, 11:12 AM
euro911   Andy, do you know what type of brake pads you have...   Mar 1 2012, 12:41 PM
balljoint   My Tacoma is the V6, 4 Door, TRD model, 4x4 with t...   Mar 2 2012, 09:12 AM
balljoint   To further make the point for flat towing. It is ...   Mar 2 2012, 10:42 AM
andys   Mark, I have the standard TRD pads. Dave, agreed...   Mar 2 2012, 10:56 AM
balljoint   We have had F450s, Internationals and Hinos for wo...   Mar 14 2012, 01:49 PM
6freak   I get an easy 24MPG ..26 if i nurse it along..2004...   Mar 14 2012, 02:00 PM
6freak   I get an easy 24MPG ..26 if i nurse it along..200...   Mar 14 2012, 04:01 PM
brant   we did a 2800 mile tow from colorado to san diego ...   Mar 14 2012, 03:13 PM
Scarlet75   I have towed 3 different 914'swith my Tacoma a...   Mar 15 2012, 04:01 AM
matt5596   I'm currently towing my first 914 with a 08 Ta...   Mar 22 2012, 10:36 AM
6freak   I'm currently towing my first 914 with a 08 T...   Mar 22 2012, 02:50 PM
messix   i have towed alot... a heavier truck the better, ...   Jun 8 2012, 07:19 PM
Dasnowman   I towed my teener home with my 07 Frontier V6 with...   Jun 9 2012, 12:31 AM
balljoint   Those little Nissans are about 10% heavier than th...   Jun 9 2012, 03:24 AM
euro911   We've only towed flatbed trailers with our ...   Jun 9 2012, 10:10 AM
- Lo-Fi Version Time is now: 21st March 2026 - 03:02 AM
