| jcambo7 |
Mar 21 2012, 12:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,702 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
I have a 1970 911 6 Cyl 2.2T in my teener. My question is about the distributor and how it works. I understand the whole rotor and cap system and how that works. More curious about the internals(gears?) and the weights. I have been told a little bit but would like some clarification. Something I have heard is that if the weights in the distributor are not working properly then the timing will be off?
Thanks (IMG:style_emoticons/default/beerchug.gif) |
| Prospectfarms |
Mar 23 2012, 08:02 AM
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
Don't know a thing about 6 cyl. porsche engines, however, there's a world of info about Bosch distributors on the "net." Try 914world, rennelist, and SAMBA.
There's some fantasy posted about renovation. For example, you will had folks suggest "rebuilding" NLA OEM Bosch distributors is simple. Not really. A while back I "rebuilt" a ".050" and, IIRC, a .028." Couldn't find the hardware I needed/wanted. Ended up merely disassembling and cleaning. Had to pull one twice to fix what I'd botched. After, they both worked better and much easier to set timing all the same. Distributor's are easy to remove, usually. I find it harder to do that with type 4 than others. Again, don't know about 2.2. 6 cyl. Good luck |
jcambo7 Distributor question Mar 21 2012, 12:27 PM
Bob L.
I have a 1970 911 6 Cyl 2.2T in my teener. My qu... Mar 21 2012, 12:34 PM
underthetire Pretty sure all dizzys use the weights, at least t... Mar 21 2012, 01:41 PM
jcambo7 My distributor doesn't have a vacuum advance. ... Mar 21 2012, 02:10 PM
Bob L.
My distributor doesn't have a vacuum advance.... Mar 21 2012, 04:06 PM
jcambo7
My distributor doesn't have a vacuum advance... Mar 21 2012, 10:21 PM
jcambo7 :bump: Still looking for some answers please? Mar 22 2012, 03:35 PM
Bob L. My knowledge on dizzys is theoretical. I would hav... Mar 22 2012, 08:16 PM
Mark Henry Take the dizzy right out, cap off.
Now push the s... Mar 22 2012, 08:50 PM
euro911 ... Last time I asked the going rate was $5-... Mar 23 2012, 01:24 AM
jcambo7
Now push the ... Mar 23 2012, 09:15 AM
jcambo7
Don't know a thing about 6 cyl. porsche engin... Mar 23 2012, 09:16 AM
underthetire Like the old saying goes, when in doubt, pull it o... Mar 23 2012, 10:41 AM
Mark Henry That rebuild price I quoted was a guy recommended ... Mar 23 2012, 10:57 AM
jcambo7 Pics of my Dizzy
Mar 23 2012, 11:47 AM
jcambo7 More
Mar 23 2012, 11:48 AM
jcambo7 So I used some carb cleaner and than sprayed some ... Mar 23 2012, 11:49 AM
underthetire Spray it down the center. Maybe take a pick and re... Mar 23 2012, 01:09 PM
jcambo7
Spray it down the center. Maybe take a pick and r... Mar 23 2012, 01:27 PM
jcambo7 <Edit>
Double post... Mar 23 2012, 01:28 PM
underthetire Right down the center of th hole. Think a snap ri... Mar 23 2012, 01:32 PM
jcambo7
Right down the center of th hole. Think a snap r... Mar 23 2012, 01:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:13 PM |
